True or False
My Berk Technology Test Pipes do not throw a CEL. Somebody recently told me that as long as there is no CEL, then you will pass emissions. Is this true, because ive also heard that if you have no cats, you'll fail.
if you don't have cats then the sniffer test will fail horibly on HC's
if they don't do sniffer test, then maybe
some areas just check for "system readiness results" kind of a self check the ECM does periodicly... no check engine light could pass you
I would just pay $200 and have it "electronicly" done
... I don't know how it is done in NC, but in cali smog shops can submit smogs via electronic submission. it allows the possibity of a "friend" superimpose a "stock" smog result onto your mosquito killer... thus a pass without even having to go to the smog station
the proper way to do an inspection in NC is to put it on some type of lift so you can inspect some stuff but most shops are lazy. As long as there is no CEL light, you are good. if you reset your battery just to turn off the CEL light, inspection wont work until you drive 50 miles which the light will turn back on if you do have somethign wrong. i know a lot of people try and do this but it wont work.
When i lived in Nevada, they had SMOG which they put this device into your exhaust and it would take readings to their machines.
we just have regular emissions. your inspection info will go to the DMV office for you to renew your tags since that's the new rules in NC.
they are talking about smog test which is their form of inspection.
you need to make friends w a local shop who can reccomend "thier guy"..( think i will pass emmissions now? You bet i will.. thru the backdoor tho) and help you out w many of these simpler question too.
im telling ya, go find the local shop and hang out, and buy some stuff from them.
lolwatbro
Oct 9, 2021 04:58 AM
m_0g
Jun 3, 2021 10:05 AM
