Kinetix High Flow Catalytic Converters Smog Question
I'm due for a smog and I believe my cats are on their way out (High NO) readings. Has anyone used the Kinetix high flow cats and had a smog check done? (California) I know that they don't have the CARB sticker.
just let your car run for 10-20mins before the smog test(to heat up your cats), and some people overfill their tires before the test(make sure u bump em back down to specs afterwards). if you have to wait in line, let your car run. also clean your EGR valve if you havent inna while(if you have one) GL...
NYGiants0186
Sep 8, 2015 10:37 AM
