Fed up with my exhaust cracking every *%$#ing where.
Old Nov 21, 2011 | 05:16 PM
  #41
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
The reason for having an exhaust ground is because vehicles with individual injectors and spark plug coils can create pulses on the vehicle wiring system through the exhaust. Apparently, the exhaust pipe can be excited to radiate the pulses and these ground straps help reduce that.
Old Nov 21, 2011 | 05:19 PM
  #42
e30cabrio's Avatar
e30cabrio
Not arguing but my car has been like this for about 3k and the strap was hanging down disconnected for about 10k before that.
Old Nov 21, 2011 | 05:22 PM
  #43
3hree5ive0ero
Retired Admin
Yeah, you're not alone. Many people do just fine without the ground strap properly attached. Although manufacturers put them ground strap there for a reason, I'm sure the effects are very minute, if not negligible. I just posted for the sake of sharing information and to clarify that it has nothing to do with moisture/rust.
Old Nov 21, 2011 | 05:26 PM
  #44
e30cabrio's Avatar
e30cabrio
When I found it, I had no idea where it belonged. As I no longer had the stock exhaust, it's mounting point was gone. I attached where it reached.
I am getting the rest of the GTSPEC braces tomorrow or Wednesday so I have to take that bolt off and I'll leave it hanging. Next time I go to the exhaust shop I'll ask him to weld it to the exhaust.
Old Nov 21, 2011 | 06:04 PM
  #45
ronn1's Avatar
ronn1
Here's *good one*..take it or leave it
http://www.beastmodeperformance.com/...roducts_id=603
TThe Zero/Sports V-Two Point Muffler Ground is a wire grounding system for the muffler and transmission. A tendency for the obstruction of air flow occurs in the exhaust when static electricity builds up during high speeds. By installing the Zero/Sports V-Two Point Muffler grounding wires, static electricity inside the exhaust is removed, smoothing air flow and making the exhaust more efficient. Besides helping to prevent corrosion inside the exhaust pipes, this product also acts as a transmission ground to improve torque response. This product works on all automatic and manual Subarus
Old Nov 21, 2011 | 06:06 PM
  #46
e30cabrio's Avatar
e30cabrio
Damn, if I only had a Subaru!
Old Nov 21, 2011 | 07:26 PM
  #47
Spork's Avatar
Spork
Get stiffer motor mounts or just fill yours with urethane to tone things down a bit.
My exhaust is stiff all the way from the turbos. I'm more worried about breaking the studs off than the exhaust breaking.
I'll be adding a grounding strap to my exhaust, at least... it's free so why not?
Old Nov 23, 2011 | 04:05 AM
  #48
phreaktor's Avatar
phreaktor
Design Engineer
Thanks for getting the thread back on topic Sporkles.
Old Nov 23, 2011 | 04:22 AM
  #49
blasian's Avatar
blasian
Is the exhaust made of recycled toasters?
Old Nov 23, 2011 | 04:24 AM
  #50
e30cabrio's Avatar
e30cabrio
Sorry.
And I had this done today:
sales@czp
Sep 23, 2019 03:30 PM
Twenty4
Jan 17, 2016 01:20 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
