Motordyne throttle body heater question
I recently purchased the Powerlab plenum spacers from a member on here..
https://my350z.com/forum/intake/5432...nt-bypass.html
it comes with the motordyne copper tb heater..my question is do i need to install the tb heater? i live in NY and it does snow here..and if i do install it..do i use it all year round..or just when its snowing or cold..?
would you uninstall it in the summer time..cause it does get hot..or you just leave it installed all year round..does it effect any performance power with it on all year round in hot weather..?
thanks for the replys
You live in a cold climate and it is a heater. It does bypass the factory heater (which heats the plenum also) and it isolates the heating effect to just the throttle body. I have one, and it does keep the plenum cool while keeping the throttle warmish (more than freezing)
All it does is "thermally isolate" the plenum from the throttle body.
It's just a copper sandwich plate you're heating up instead of the entire plenum. You're basically just rerouting coolant flow. It can be beneficial but is very minor.
The reason why manufacturers have to run coolant through the plenum is to prevent the TB from freezing over in colder climates. Now if you just run the coolant through this plate that warms up the TB, you don't have to heat the entire plenum. Will it affect performance? Not that much... you can argue that if the plenum is colder you will have denser air going in but in terms of performance, it's minimal.
The aramid gasket sold by MD however is more useful as that's a heatsink you'd put between two things that get really hot. Now if you put a thermal brake in there it'd prevent conduction.
In any case, use the Motordyne copper throttlebody heater. If you live and drive in NY or a similarly cold environment always use the copper throttle body heater.
350Z_Al
Oct 29, 2020 07:44 PM
