Y-pipe dragging
Old Jan 31, 2012 | 05:45 PM
J1mb0's Avatar
J1mb0
Default Y-pipe dragging
Havent seen any answers for my question so here it goes.
My Z is a DE and has Megan racing resonated TP and Y-pipe (HR style) with a JIC exhaust. The problem is that my Y-pipe hangs due to the flex joints and scraps on everything.
Does anyone have a solution besides trading y-pipes?
Thanks
Old Jan 31, 2012 | 05:58 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Pictures? Do you have an OEM HR y-pipe or Megan? Does it hang lower than your OEM DE y-pipe?
Old Jan 31, 2012 | 06:00 PM
J1mb0's Avatar
J1mb0
I'll have pictures tomorrow. It's Megan racing and yes much lower than OEM.
Old Jan 31, 2012 | 06:02 PM
AdvanZ33's Avatar
AdvanZ33
Good to know, I was thinking of getting that y-pipe but I don't want anything that hangs lower than stock.
Old Jan 31, 2012 | 06:11 PM
J1mb0's Avatar
J1mb0
Don't get me wrong, I like it a lot. Just gotta figure out why it hangs so low
Old Jan 31, 2012 | 06:12 PM
AdvanZ33's Avatar
AdvanZ33
If for the results. I have speed bumps to overcome
Old Jan 31, 2012 | 06:13 PM
J1mb0's Avatar
J1mb0
Speed bumps <<<<<
Old Jan 31, 2012 | 06:20 PM
ronn1's Avatar
ronn1
Thanks
Found this pic of Megan Y with STOCK CATS..note the CAT support bracket is there. With TP, you don't have it now.
Maybe this Y pipe weighs more and with the CATS not being supported by the bracket, causes sagging.
Old Jan 31, 2012 | 06:26 PM
J1mb0's Avatar
J1mb0
Thats not the same y-pipe. I'm going to call Megan racing tomorrow and ask them
Old Jan 31, 2012 | 06:58 PM
ronn1's Avatar
ronn1
This is what they show here...
http://www.wesellcarparts.com/store/...idproduct=3468
But I see they updated the pipe...guess you hav this one then:
http://www.meganracing.com/product.a...d=298&catid=10
- Our newest revision, pictured, features an extended collector further down the exhaust path to help with exhaust scavenging properties to maximize flow. This more recent revision is designed off of the "HR" engine, while the previous version was designed off of the "DE" engine-- the newer revised version will still fit all model years 2003-2007 Nissan 350Z and G35. The photo of the Y-pipe on the vehicle is the previous version
Old Jan 31, 2012 | 06:59 PM
J1mb0's Avatar
J1mb0
Yes I have the updated y-pipe
Old Jan 31, 2012 | 07:18 PM
Ak48z's Avatar
Ak48z
I don't think mine hangs any lower than stock... I have stock cats though.
Old Jan 31, 2012 | 07:29 PM
ronn1's Avatar
ronn1
Yeah..pipes are much farther out..looks like weight is shifted to outside and could sag more there...less ground clearance there vs center under drive shaft?
Here is a Megan on a G37, but set up is similar..pipes are way out and you need to remove plastic covers there too.
Old Jan 31, 2012 | 07:34 PM
J1mb0's Avatar
J1mb0
I just saw that picture. Yea I had to remove the plastic covers but that didn't bother me. The reason it hangs is because there isn't any hangers or supports from the TP to the mid pipe. Im going to call Megan racing and explain too them that they need some kind of support brackets.
There is a spot that's close to the middle of the y-pipe that would work if the y-pipe had brackets. Maybe they will redesign it again lol
Old Jan 31, 2012 | 07:50 PM
Ak48z's Avatar
Ak48z
I'm sure you could have a local shop fab you up a bracket and weld it to the y-pipe if need be.... Is your mounting point on the midpipe solid?
Old Jan 31, 2012 | 07:51 PM
J1mb0's Avatar
J1mb0
Went to try it today and a shop quoted me $80. They said it wouldnt hold if I hit a speed bump.
Also I'm getting a hissing sound when I'm in neutral or decelerating. I think that is due to the y-pipe hanging and not sealing with the gaskets.
Old Jan 31, 2012 | 09:21 PM
R350Zz33's Avatar
R350Zz33
just buy some pipe straps and bolt it up
If the exhaust was dragging sparks would be shooting from under the car at night. Doubt if you would drive. Are you exaggerating?
Old Jan 31, 2012 | 10:36 PM
ronn1's Avatar
ronn1
It really shouldn't sag at all...most of us have cat backs (X or Y pipes) without problems like this. It must be Megan's redesign and weight.
Take it to a muffler shop and see if you can get some hangers set up...Might just wanna see if Megan can get you old style.
Old Jan 31, 2012 | 11:21 PM
terrasmak's Avatar
How low are you , the Y pipe is the lowest part of the car.
