how to fix exhaust leak??
Old Mar 1, 2012 | 03:46 AM
gotmeaZ's Avatar
gotmeaZ
Default how to fix exhaust leak??
i have two exhaust leaks on my hks. one on the passenger side where the test pipe connects to the h pipe, then another on the passenger side right where the muffler connects to that pipe that runs over the rear sway bar. everything has been done to try and fix it. i've loosened it up, tried moving the gasket aroud, loosening it up and just re-bolting it down. but nothing works. its not an awful leak, like a gap or anything, but when everything is bolted down tight, i can put my hand over the connection and feel air coming out.
is there any kind of sealant/bond i can buy to fix this? i really dont wanna get them welded together, so thats out of the question.
also, how big of a performance loss is this causing me? much at all? a ton?
thanks!
Old Mar 1, 2012 | 03:51 AM
dmroberson's Avatar
dmroberson
swap the gaskets out?
Old Mar 1, 2012 | 04:07 AM
taywan's Avatar
taywan
I wouldnt weld that.
Old Mar 1, 2012 | 05:05 AM
hyuk28719's Avatar
hyuk28719
New gasket imo would be your best option. Yes leak is bad and if i know where it comes from then i'd fix it
Old Mar 1, 2012 | 09:49 AM
gotmeaZ's Avatar
gotmeaZ
the gaskets are basically brand new. why would the gaskets be causing the problem?
Old Mar 1, 2012 | 02:08 PM
OkashiZ's Avatar
OkashiZ
could have been lined up slightly off and rattled itself out of place. check the gaskets and replace them if necessary.
Old Mar 3, 2012 | 01:49 PM
thekinn's Avatar
thekinn
slap some RTV in there as a gasket
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
