AEM Gauge-Type Wideband UEGO Controller
Old Jan 2, 2004 | 01:02 PM
VandyZ's Avatar
VandyZ
Originally posted by teh215
OK. The sensor is included in the kit according to AEM website. I have found a vendor that will do them for $320 each if I can get 10 people to sign up. This price includes shipping but to only 1 location. They would have to be shipped to me and I would inturn ship them to you. Let me know.
I knew it could be done!
I may be able to convince Doug and Chris (maybe others too). That is a terrific price!
Old Jan 2, 2004 | 01:27 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I'm in for sure!!!!! Just let me know wheer to sign!!!
Gurgen
Old Jan 2, 2004 | 03:11 PM
teh215's Avatar
teh215
Old Jan 3, 2004 | 09:19 AM
PhoenixINX's Avatar
PhoenixINX
Bump for possibly two more.
Question - who did the WB for AEM?
And how large is the guage?
Old Jan 3, 2004 | 09:33 AM
teh215's Avatar
teh215
I am assuming that AEM designed and manufactured the kit in house but, I cannot say for sure. The gauge size is 2 1/16" diameter. Here is the info from their site:
AEM’s Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit!
AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Key Features:
∙ 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda
∙ Integrated three-digit display reveals AFR or Lambda in real time
∙ User-programmable 0-5v analog output included for use with data loggers and ANY engine management system
∙ Ideal AFR monitoring tool for carbureted applications and engine dynamometers
∙ Does not oscillate AFR like narrow band sensors
∙ Serial data stream included for output of AFR (RS 232)
∙ Accurate to 0.1 AFR
∙ Bosch sensor included
Old Jan 3, 2004 | 03:47 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Any ETA's for this unit?
I am planning on combining it with an EGT gauge for ultra-safe monitoring of my current NA as well as the upcoming TT setups.
How much can a good EGT gauge kit go for - any advice?
Gurgen
Old Jan 3, 2004 | 06:07 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I think Greddy makes a great EGT gauge.. It's around $200-$300 I think?
Old Jan 3, 2004 | 10:02 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I have the Silver Greddy EGT and Boost gauges:
Attached Thumbnails AEM Gauge-Type Wideband UEGO Controller-procharger-046.jpg
Old Jan 3, 2004 | 10:31 PM
apex locator's Avatar
apex locator
i am interested also, if it comes w/ sensor + gauge for that 320 price.
Old Jan 4, 2004 | 06:32 AM
KJY9's Avatar
KJY9
Put me down for 1 as well
Old Jan 4, 2004 | 07:33 AM
greddy4777's Avatar
greddy4777
i'm in...let me know the details.....
Old Jan 4, 2004 | 07:53 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
teh215: Looks like we have more than enough now. Let's get this thing going!
Old Jan 4, 2004 | 09:05 AM
MySunset350Z's Avatar
MySunset350Z
im in for sure...lets get this thing going!
Old Jan 4, 2004 | 09:24 AM
jreiter's Avatar
jreiter
In a V engine, wouldn't 2 sensors be needed? If only one, where do you mount it? You've got an exhaust manifold coming out of each side of the engine, so wouldn't you want a sensor on each side? Wouldn't that mean you'd have to have two of these gauges, too?
I also noticed that the Horsepowerfreaks site (linked up above) sells AEM wideband O2 sensor kits seperately. They specifically have single channel and dual channel kits, the latter being for V style engines. Will we need to get an extra sensor for the Z, and if so, will the gauge even support a dual channel setup?
Using only one sensor on one side of the engine, it would seem that you'd only be measuring the AFR from one bank of cylinders. That would work as long as you don't get a problem in a cylinder on the *other* side.
Old Jan 4, 2004 | 09:39 AM
jesseenglish's Avatar
jesseenglish
jreiter, you're correct.
There is only one sensor and the gauge can only support one sensor. The engine should be running balanced A/F ratios between the two different sides, so it should be fine if you just monitor one side.
If you wanna get real technical, you should have six Wideband sensors and six gauges, one for each cylinder, but that's getting a little ridiculous. Just tune conservatively to make up for any airflow differences between the three cylinders on the same bank and there's no problem just monitoring one bank.
Old Jan 4, 2004 | 09:44 AM
MySunset350Z
was it cylinder 1 or 6 that tends to be running somewhat more lean then the rest?
i'd just put it on that side and call it a day. this way i get a worst case scenario a/f.
Old Jan 4, 2004 | 09:55 AM
jesseenglish
Well, it would definitely be one of the rear cylinders, because of the plenum design. Most people have complained about problems with #6.
  #38
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
IIRC its #6....what MySunset described is exactly how you wouold measure it, as well as EGT
Old Jan 4, 2004 | 11:00 AM
  #39
daking350's Avatar
daking350
I am in put me on the list....
Old Jan 4, 2004 | 11:16 AM
  #40
teh215's Avatar
teh215
At the rate that this is going, do you think I should see if I can get a better price for 20 of them?
