Just Installed Injen CAI - Squeaks Before Revs
Hello all, I just installed an Injen cold air intake on my completely stock 2003. When I rev the engine I get a high pitched squeak right before the engine sound builds up. It's annoying, what could be causing this?
I thought I had an air leak somewhere, so I took the intake completely apart and reinstalled the whole thing and it still does it.
Also, at the end of the video, you can see when the needle falls back down it goes down to like 400rpms and almost stalls out. It's only been doing this since I installed the intake yesterday.
http://www.youtube.com/watch?v=kPZ8V6x4Ajg
Here's a video that I shot with my phone.
Thanks.
Thanks.
Sounds like just air being sucked into the CAI.
On the stalling problem...you sure all connectors/clamps have a good seal?
Especially important at your air sensor.Also,did you disconnect the battery(negative
pole)while doing the installs?Or,did you start the car during the install?
Possibly you need to reset your ECU with the standard procedure.
