Header to Cat Gasket
Old Jun 7, 2012 | 07:08 AM
CLyons0203's Avatar
CLyons0203
Default Header to Cat Gasket
Where can I get a header to cat gasket for the HR motor? The Nissan O ring does not work with aftermarket headers or cats. I know Berk sells one.
Plan on doing a header install this weekend would like to find one local. Maybe I can buy some MR.Gasket gasket sheet and cut out my own?
Old Jun 7, 2012 | 11:02 AM
User 42426's Avatar
User 42426
try an exhaust shop around your area. I was in the market for gaskets once, and the online sites charge 5-10 for ONE gasket, I got gaskets for a dollar at my exhaust shop
Old Jun 8, 2012 | 09:28 AM
CLyons0203's Avatar
CLyons0203
fyi...Napa Auto sells gasket material sheets. $12 for a 3 layer high temp gasket sheet
Old Jun 8, 2012 | 07:38 PM
ronn1's Avatar
ronn1
Don't cheap out...get BERK gasket. Either order from their web site ( I did) or do a search..lot of vendors here sell em. It's a HIGH TEMP graphite (crush type) gasket. I have it on my HFC. Make sure it's for HR application ( I assume you have HR).
Old Jun 10, 2012 | 08:35 PM
CLyons0203's Avatar
CLyons0203
Im running 370Z headers which are the same has HR headers but have an extra heat shield around the collector. Uses the same gaskets as HR headers. The gasket stuff napa uses is tri layer high temp stuff. The hard part was cutting the material with scissors and cutting the inner hole. But they work
Old Jun 10, 2012 | 09:51 PM
ronn1's Avatar
ronn1
Why go through the hastle?
Here's the Berk for 370/HR cars...$20 for the set precut:
http://www.berktechnology.com/produc...llector-gasket
Old Jun 11, 2012 | 06:21 AM
J.$'s Avatar
J.$
I work for a HUGE exhaust distributor, we have literally thousands of gaskets in stock. Give me a part number that's either ROL, IMCO, or Marwill, I can check to see if we can have it.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
