Odd Buzz From Rt Cats
Old Jan 9, 2004 | 05:33 AM
OldManZ350's Avatar
OldManZ350
Default Odd Buzz From Rt Cats
INSTALLED RT CATS WITH STOCK EXHAUST. THERE IS A ODD BUZZING OR METAL SOUND COMING FROM THE EXHAUST OR RT CATS. I'VE CHECKED CLEARANCE IN EVERY AREA OF THE EXHAUST, INSTALLED THE SHIMS ON CROSSMEMBER. IT IS NOT HITTING OR RUBBING ANYWHERE. SITTING STILL YOU FLIP THE THROTTLE UP TO 25OO RPM, AS THE R'S COME DOWN YOU HERE THE BUZZING OR METAL SOUND. WHEN DRIVING, THE BUZZ IS AT 4300 RPM TO REDLINE. ANYBODY WITH AFTERMARKET CATS HAVE SIMILAR PROBLEMS? HELP PLEASE.....
Old Jan 9, 2004 | 07:03 AM
Ultimateone's Avatar
Ultimateone
Almost sounds like the problem people have with test pipes....hmm I guess double check all the bolts twice.
Old Jan 9, 2004 | 06:09 PM
350zdanny's Avatar
350zdanny
nah the problems with test pipes does not continue to redline. it is localized usually between 3 and 4k rpm. it sounds like you have a loose bolt somewhere.
Old Jan 9, 2004 | 06:13 PM
OldManZ350's Avatar
OldManZ350
THERE IS NOTHING LOOSE, I'VE CHECK EVERTHING 3 TIMES.
Old Jan 9, 2004 | 06:16 PM
350zdanny's Avatar
350zdanny
kill the damn caps. the button is 7/16's of an inch away. then maybe you checked something wrong. i was just trying to help.
Old Jan 9, 2004 | 06:17 PM
OldManZ350's Avatar
OldManZ350
ANYBODY OTHER THAN A BONEHEAD ON THIS SITE?
YOU KNOW WHO I'M TALKING TO.........
YA...... IS YOU DANNY BOY..........
READ MY POST.......
Old Jan 9, 2004 | 06:24 PM
OldManZ350's Avatar
OldManZ350
WHAT????????????
Old Jan 9, 2004 | 06:39 PM
Phatmitzu's Avatar
Phatmitzu
Theres only one "BONEHEAD" here I see...and Im looking at it
Old Jan 9, 2004 | 06:44 PM
Z PHAT Z's Avatar
Z PHAT Z
TIMROD1011
They asking you to turn off the CAPS lock. People on the net don't like CAPS and they think that you are yelling and it's not polite .
Old Jan 9, 2004 | 07:15 PM
spazpilot's Avatar
spazpilot
if your getting a buzz check and make sure your not leaking from the flanges. They could be warped which no matter how hard they are tighten down it will still leak. feel for air coming out from the flanges and yes keeping it in caps lock means your screaming so please take it off
Old Jan 9, 2004 | 07:26 PM
350Z 2+2 ???'s Avatar
350Z 2+2 ???
I suspect that it's either an exhaust leak as mentioned already, or you have some tension on your Y-pipe and the buzzing is actually coming from the flex sections in your Y. I would recommend loosening the bolts that mate up to your Y-pipe and move the pipes around slightly allowing them to "relax". Then tighten everything up again and hopefully the buzzing will be gone. Good luck!
Old Jan 9, 2004 | 07:38 PM
droideka's Avatar
droideka
READ MY POST.......
What a ****ing douche bag. Nobody help this n00b *****.
Old Jan 9, 2004 | 10:36 PM
ricochet's Avatar
ricochet
Hmm... I get the same thing with the RT cats w/ Nismo exhaust. A localized buzz between 3500-4000 RPMs. Doesn't exist above and below, and only prominent in the RPM band stated while in WOT. What is causing it for the test pipes? Resonance? Or rubbing and/or leak?
Old Jan 10, 2004 | 05:06 AM
OldManZ350's Avatar
OldManZ350
Thanks for the help guys...... I will do just that "TODAY". I don't think have a leak but I guest it is worth checking agin. This should be a very simple installation. I will let you all know if this corrects the problem. Thanks!
Old Jan 12, 2004 | 05:08 PM
skrofa14's Avatar
skrofa14
same thing on my g35 coupe with R/T cats and stock exhaust, only during WOT though ?? Everything triple checked ???
Old Jan 13, 2004 | 05:29 AM
OldManZ350's Avatar
OldManZ350
YES..... THE CLOSER TO WOT THE LOUDER THE BUZZ, BUT IS ONLY AFTER 4000 RPM.
Old Jan 13, 2004 | 06:22 AM
devildogg's Avatar
devildogg
I HAD the same problem. A vibration at 4k rpm's. I purchased my RT cats from Performance Nissan. I installed one shim on each bolt as instructed, it vibrated. I then doubled up the shims on the front bolts that gave them a little more space. No more vibration, try that.
Good Luck!
Old Jan 21, 2004 | 04:09 PM
BrianLG35C's Avatar
BrianLG35C
Good Luck!
I just had my Nismo Exhaust & Rt Cats installed too with the same problem. Did you get more shims from Jason/Performance Nissan?
Old Jan 22, 2004 | 04:08 AM
devildogg's Avatar
devildogg
No! I didn't use the shims on the rear most bolts. I just put 2 each on the front bolts. Works fine.
Good Luck...
Old Jan 22, 2004 | 06:39 AM
BrianLG35C's Avatar
BrianLG35C
Good Luck...
Thanks a lot for your help devildogg!
