PPE Longtube Headers
Old Jan 23, 2013 | 05:33 PM
  #921
indyz33's Avatar
indyz33
Originally Posted by denchan350gt
just wires and shrink tubing
Ok thanks man. That's what I was wondering.
Old Jan 25, 2013 | 11:12 AM
  #922
MM'08_350Z's Avatar
I'm a happy camper!!!
Old Jan 25, 2013 | 11:42 AM
  #923
doshoru's Avatar
doshoru
I'm thinking I should have gone with stepped, too
I still haven't even installed mine...too busy with house renovations.
Old Jan 25, 2013 | 12:11 PM
  #924
MM'08_350Z's Avatar
I know this is a dumb question but what is the differance between stepped and non-stepped?
Old Jan 25, 2013 | 12:47 PM
  #925
cyc5181's Avatar
cyc5181
you bought yours without knowing the difference? lucky you there arent much difference, but u can find the answer in this thread.......
Old Jan 25, 2013 | 04:41 PM
  #926
MM'08_350Z's Avatar
Alriaght I just compared and I got Stepped LTH ;D
Old Jan 25, 2013 | 04:44 PM
  #927
2004Black350z's Avatar
2004Black350z
Exhaust Whore
ordering mine in 2 weeks
Old Jan 25, 2013 | 05:26 PM
  #928
0jiggy0's Avatar
0jiggy0
I talked to PPE directly and I forget his name, but the main guy that came up with these designed the stepped with the HR's in mind. The non stepped came from Denchan with a nonrev DE. These were basically designed for the HR and then made to fit the DE. He doesn't recommend the non stepped for HR's but will make them for you if you really want them.
Old Jan 26, 2013 | 05:18 PM
  #929
denchan350gt's Avatar
denchan350gt
True statement I guess you talked to Paul. I've had mine installed for over a yr with no issues.
Old Jan 27, 2013 | 11:18 AM
  #930
06platinumG's Avatar
06platinumG
Default Decibel level
Here’s my question, for those of you that have swapped shorties and straight pipe or ART pipe for the long tube, are they any louder. I’m getting ready to go one way or the other and understand that performance wise the long tube have a slight edge but I’m concerned with the overall decibel level. I understand that they are louder than stock but how due the two options compare. Tracks are getting more and more restrictive on the decibel level and I don’t want that to be an issue. Has any one done a decibel reading comparing the two options?
Old Jan 27, 2013 | 12:26 PM
  #931
KingBaby's Avatar
KingBaby
Hardest Setting
Don't go longtubes then! I havent gone WOT fully yet, but after 3-4k it's way louder than my test pipe stetup!
I know doesn't help much, but Depending on y-pipe back you may be able to tone it done a bit.
What's your current setup?
Old Jan 27, 2013 | 01:02 PM
  #932
0jiggy0's Avatar
0jiggy0
Yes, paul that's his name.
Old Jan 28, 2013 | 07:17 AM
  #933
denchan350gt
Yes it will be louder, but as Kingsbaby said it depends on your exhaust setup. If you have space to add resonators you can tone it down a little.
I will post a vid in a day or so comparing my setup to a Z with stock manifolds non resonated test pipes and my old exhaust invidia Gemini with MF x pipe.
My setup at the time of the vid was non resonated x, 2 12in hushpower mufflers to a IPL muffler.
New setup is MF resonated X, 2 18in hushpower mufflers to the IPL it's quieter now. I lost a couple hp/tq due to the merge now being further back.
Old Feb 4, 2013 | 01:27 AM
  #934
MonkeyMagic72's Avatar
MonkeyMagic72
Just order the PPE LTH for my HR. I was lucky enough to order before the price jump. I wish I would have bought these when groupbuy was available. Oh well, I still got a good deal. I am still waiting for my LTH to ship. My setup will be all out performance, LTH and full Tomei titanium y-pipe and exhaust single exist setup. Hey guys, any chance someone will write a thread DIY LTH installation for the 350Z. If not, what is your advise for easy tackle OEM headers removal and cats, with detailing steps.
Old Feb 4, 2013 | 01:56 AM
  #935
bmyles's Avatar
bmyles
This is the best How-To I've seen: https://my350z.com/forum/engine-driv...tallation.html
Old Feb 4, 2013 | 02:07 AM
  #936
KingBaby's Avatar
KingBaby
Hardest Setting
Tools tools tools...
Make sure you have them before attempting, other than that is easy now that I've done it!
Old Feb 4, 2013 | 02:46 AM
  #937
MonkeyMagic72
Thanks for the link, bmyles. Has anyone try to remove the six nuts of on the exhaust manifolds and carefully take them out from the bottom while the cats or test pipes still attached? Also, how well do PPE lth fit when is installed? Any clearance issues or rubbing with fuel lines like the nismo headers did? I am just trying to get some head up advise before I tackle this bastard removal and installation.
Old Feb 4, 2013 | 08:00 AM
  #938
cyc5181's Avatar
cyc5181
there's answers you can find in this thread. and I also wrote down some stuff that I encountered during my installation. it's under the DIY section.
don't understand why you want to take the manifolds out with the TP/cats still attached.................
and it's definitely louder. I went from oem with cats to PPE. night and day difference in terms of sound. it sounds........ loud and mean, kinda like a V8....... and you can forget about keeping the VQ sound. I have a MD exhaust fwiw.
Old Feb 4, 2013 | 09:18 AM
  #939
KingBaby's Avatar
KingBaby
Hardest Setting
Originally Posted by cyc5181
and you can forget about keeping the VQ Stock sound. I have a MD exhaust fwiw.
stock sound will be no more, only the awesome will be left
cheesy but true
Old Feb 4, 2013 | 10:32 AM
  #940
redline06's Avatar
redline06
Might still retain a bit of that VQ purr if you have a nismo exhaust
