invidia n1 exhaust goes best with which y pipe?
Old Nov 8, 2012 | 07:35 PM
matthew felbz's Avatar
matthew felbz
Default invidia n1 exhaust goes best with which y pipe?
hey peeps just ordered my invidia N1 and now im looking into the best y-pipe for this exhaust ? i have a 03 preformance edition injen cai skunk2 plenum spacer i wanna above all else avoid rasp and hiss HELP would be amazing
Old Nov 8, 2012 | 08:20 PM
Bmurray350z's Avatar
Bmurray350z
the invidia n1 has 2.5" piping.. and all aftermarket y pipe have a 3" outlet.. it'd just be choking up your exhaust a little. just keep stock.
Old Nov 8, 2012 | 08:26 PM
terrasmak's Avatar
Motordyne is all you need to know
Old Nov 8, 2012 | 10:57 PM
matthew felbz
motordyne eh? pricy i was thinking maybe ichiba y pipe? invidia diameter is 2.32 inches and ichiba is 2.5 and is a decent brand name aswell for alot less now im wondering if everything would fit up nice cheers
Old Nov 9, 2012 | 06:22 AM
Bmurray350z
the inlet to the y pipe is 2.5", but the outlet (connects to the exhaust) is 3" diameter. again, you do not need to get an aftermarket y pipe with that exhaust system.
Old Nov 9, 2012 | 09:57 AM
AngelsVQ's Avatar
AngelsVQ
gains are minimal with any bolt on, just leave the stock y pipe on
Old Nov 9, 2012 | 11:18 AM
WillyP28's Avatar
WillyP28
I have the Ichiba y pipe with the Invidia n1 exhaust and Iam happy with this setup. The Ichiba y pipe is by no means the best y pipe and like what the other users said the gains are minimal. I really wanted to change my y pipe without spending a lot and this is the brand I went with. The first time around I had a Megan y pipe and that broke on me. So it all kind of depends on your budget but there are brands better than Ichiba.
Old Nov 9, 2012 | 12:58 PM
matthew felbz
think i would be better getting a pair of high flow cats?
Old Nov 9, 2012 | 01:26 PM
WillyP28's Avatar
WillyP28
Yes and everyone would advise you to do the same. I went with resonated test pipes instead of high flow cats but again you need to figure out what your goals are and how much you want to spend.
Old Nov 9, 2012 | 01:29 PM
Bmurray350z
Considering it'd be stupid to go from large piping to small piping with a y pipe, yes.. high flow cats will do much better.
Old Nov 9, 2012 | 05:35 PM
User 42426's Avatar
User 42426
if you're going to get hfc, might as well get a y pipe too. Any y pipe will do, even megan/ebay y pipes. Just remember to keep the flow-2.25-2.5-3inch diameter so you don't get rasp. I used to run 3inch tp's mating with a 2.25 inch exhaust and had a lot of rasp, switched to nismo and no rasp.
Old Nov 9, 2012 | 05:44 PM
Bmurray350z
why would you run smaller exhaust piping, but larger test pipe/hfc piping? it's supposed to gradually get larger, not smaller.
Old Nov 9, 2012 | 06:29 PM
matthew felbz
thanks guys u helped me big time now crawford or berk was gonna go with crawford bc i read alot of berks would die out and would it be such a bad thing to keep stock y pipe for now??? do hfc give any gains? there website says they do but ppls reviews says other wise not really looking for it but would be nice i just want it to sound bad ***
Old Nov 9, 2012 | 07:30 PM
Bmurray350z
keep stock y pipe unless you get a larger diameter exhaust! berk hfc
/thread
Old Nov 10, 2012 | 03:08 PM
PhoenixBazoli's Avatar
PhoenixBazoli
sound bad ***, hmmmm
LTH? X)
LTH+stock y pipe and n1
otherwise..
any good quality y pipe, and some 3" y pipe back
I would say agency power or megan drift spec for single
or topspeed 3"
it looks just like the invidia n1, but it preforms better due to larger piping
if you're willing to spend more just go on with the MD shockwave..
if you're not going for a tune, I suggest you keep stock y pipe, n1 and LTH
good gains imo..
Tylerx7z33
Sep 21, 2015 01:43 PM
Obeorangekenobi
Sep 11, 2015 07:17 AM
BigD350
Jun 9, 2005 06:40 AM
UltraRev
Oct 8, 2004 07:11 AM
