XYZ module and HKS?
Old Dec 15, 2012 | 07:45 PM
Bumble Z's Avatar
Bumble Z
Default XYZ customed to dual exhaust
just purchased an XYZ art pipes combo. i kno every one loves the tdx/shockwave exhaust but i like the way the HKS exhaust looks better. is there any way to pair the XYZ pipe convert it to an X pipe with the module from the TDX system that clamps with the V-clamp with the HKS mufflers and pipes... i dont want to get rid of my xyz pipe for a h pipe that comes with the system i just would like to know if it would work and if its been done does it sound like crap or is it decent.
Old Dec 15, 2012 | 10:23 PM
terrasmak's Avatar
I would buy an ebay replica and start cutting to see if you can make it work.
Old Dec 15, 2012 | 10:48 PM
Bumble Z's Avatar
Bumble Z
Not a bad idea
Old Dec 17, 2012 | 09:04 AM
Classy's Avatar
Classy
You could totally make it work, but I am almost 100% sure you will end up cutting out 2 of the resonators to make it work
Old Dec 17, 2012 | 02:26 PM
Bumble Z's Avatar
Bumble Z
That or figure out to some how mount a 3" y pipe facing back and mount the mufflers to what would be the inlet part with some custom piping
Old Dec 18, 2012 | 05:03 PM
Classy's Avatar
Classy
You are seriously going to try that hard to copy a motordyne exhaust???
Old Dec 19, 2012 | 12:07 AM
Itzcashew's Avatar
Itzcashew
Cut the two resonators. Weld a one inlet to two outlet muffler on. Bolt everything up and call it a day.
Old Dec 19, 2012 | 08:53 AM
Bumble Z's Avatar
Bumble Z
Dont really want to copy it i just personally prefer the look of the HKS canisters/mufflers but recieved the xyz and art pipes as gifts and love them but dont want to get rid of em just a little bored of my ap single if i wanted the tdx i would just purchase it rather the copy it but an exhaust is manly looks n sound not much preformance
Old Dec 19, 2012 | 11:38 AM
lovemyVQ's Avatar
lovemyVQ
I've looked into this before and emailed Tony a couple times to get his input. It can be done with cutting/welding of the hks exhaust and adding 2 into 1 type muffler like Itzcashew mentioned. From what I gathered from Tony however, it's not really worth it for a few reasons. Mainly because the motordyne system is actually a system lol. It's designed around the xyz pipe with progressive pipe diameter changes. The hks is even diameter throughout. You'd be creating a large choke point close to the manifold/headers that wouldn't be beneficial. You'd definitely have to cut out the hks h-pipe and two resonators, which is a good idea regardless because they're both pieces of crap. You should either sell the motordyne pieces and use the money for whatever you will; or scrap/sell the hks exhaust and purchase the rest of a full motordyne system.
Old Dec 19, 2012 | 05:20 PM
Bumble Z's Avatar
Bumble Z
A choke point is definatly a big no no lol. I guess its either go full HKS or full MD . I havent yet to buy the HKS but i am about half way with the MD setup and i dont want to rid of them. I guess i might as well go with whats proven then experiment and end up sacrficing preformance. But thanks for your input im glad im not the only one Thats looked into this lol
Old Dec 19, 2012 | 05:48 PM
Classy's Avatar
Classy
I see where you are going with liking motordyne but wanting the muffler section of an HKS to hopefully quiet it down, the loudness of the motordyne exhaust was always a turn off for me personally...
As for choking the exhaust with the diameter changes, I am not sure how much it will matter in the end, you could seriously eliminate the entire replica exhaust except for the 2 rear muffler sections, and run a 3 inch pipe off the xyz and run a Y that branches off before the diff, pretty much the same thing motordyne did, but you would probably save $6-800 and possibly have a quieter exhaust!
I will tell you this, I kept the rear sections very clean (actually got under the car every weekend and washed them) and it stayed very pretty except for the tips eventually kinda turned to crap
Old Dec 19, 2012 | 07:44 PM
Bumble Z's Avatar
Bumble Z
Yes plus i have the xyz pipe resonated as well i was thinkin about the 3" y pipe because i go from art to xyz which is 2.25 -2.5 then 2.5-3" and if i did go replica i would def change those tips out and wouldnt need the piping just the mufflers
Old Jan 4, 2013 | 12:51 PM
Bumble Z's Avatar
Bumble Z
so i bit the bullet did a little experimenting.. purchased the m2 performance dual exhaust(megan sister company) aka hks rep... swapped out the agency power single and customized a magnaflow tranisition y pipe.... hooked this bad boy up with with my xyz resonated / art pipe set up and sounds amazing..got some low end torque back and smoother ride not so bad on the drone since the xyz is resonated... going to attempt a bumper tuck on the nismo bumper and then ill put up a clip n some pix...ps classy i didnt realize it till i looked at the bigger picture but i did use the MD shockwave concept no chocking points either as mentioned being a possibility ..
Old Jan 4, 2013 | 10:25 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
It drones?! ergh
Good job on the fabrication though, but i don't know why you wouldn't like this
Old Jan 5, 2013 | 03:31 AM
Bumble Z's Avatar
Bumble Z
Originally Posted by F2CMaDMaXX
It drones?! ergh
Not at all no drone i have it resonated but coming off an agency power its silent...as for the shockwave tdx its straight up sexy but out of my budget..
aarrgghh
May 1, 2022 11:04 AM
reno56
Interior
17
Nov 20, 2015 05:21 PM
