Hydro Sheild? for AirFilters
Old Dec 16, 2012 | 10:19 PM
andy11466's Avatar
andy11466
Default Hydro Sheild? for AirFilters
Just wondering, has anyone used a hydro shield for the airfilters, it's suppose to prevent water from getting to it..
just another marketing scam or does it work?
Old Dec 16, 2012 | 11:53 PM
daytonabluez05's Avatar
daytonabluez05
I've got one on my AEM CAI, it still gets wet though when its raining, hell it wasnt even raining, the roads were just wet and it went into limp mode. Honestly i'd say dont worry about it.
Old Dec 17, 2012 | 02:38 AM
winchman's Avatar
winchman
That sounds like a plug for stock filters and intakes.
Old Dec 17, 2012 | 08:20 AM
35thannyZowner's Avatar
35thannyZowner
you guys aren't worth the time
Old Dec 17, 2012 | 01:13 PM
TheDangerZone's Avatar
TheDangerZone
the hydro shield is for driving, of course it's not going to suck water in while washing your car. High pressure or not.
OP, I wouldn't worry about getting them.
Old Dec 17, 2012 | 02:18 PM
35thannyZowner
Old Dec 17, 2012 | 02:46 PM
35thannyZowner
Old Dec 17, 2012 | 03:09 PM
Esser's Avatar
Esser
Originally Posted by 35thannyZowner
After pulling up next to a Lamborghini, and hearing how it sounded, I got jealous. So I checked out the after market air intakes, but I decided to try something different. I originally drilled holes in the top of the intake box. I later removed the front portion of the intake box along with the intake duct, leaving the top & bottom portion. I had a friend who owned a yellow 2005 35th, and a car wash. He used a high pressure water nozzle to test it with the hood closed, and to see if there was any at all water intake. There wasn't...not even a drop. I have driven the car in all kinds of bad weather....never a problem.
IIf I turned off the TDC and I floored it, the ROAR would blow your mind!
Why would you drill holes right there???? That is stupid. All that is doing is letting hot air from the engine bay into your intake now. Notice how there are portions under the hood that seal off the area around the intake when the hood is closed to prevent hot air from getting to it? You just destroyed its purpose. This should result in warmer intake temps and less performance.
Old Dec 17, 2012 | 04:13 PM
35thannyZowner
Old Dec 17, 2012 | 11:24 PM
stascom's Avatar
stascom
After pulling up next to a Lamborghini, and hearing how it sounded, I got jealous. So I checked out the after market air intakes, but I decided to try something different. I originally drilled holes in the top of the intake box. I later removed the front portion of the intake box along with the intake duct, leaving the top & bottom portion. I had a friend who owned a yellow 2005 35th, and a car wash. He used a high pressure water nozzle to test it with the hood closed, and to see if there was any at all water intake. There wasn't...not even a drop. I have driven the car in all kinds of bad weather....never a problem...
So, um... does it sound like 12-cylinder supercar engine at 8k RPM now?
Not hating, just thought it came out funny.
Old Dec 18, 2012 | 12:39 AM
end of z world's Avatar
end of z world
Lolz^
Old Dec 18, 2012 | 08:40 AM
Waiz's Avatar
Waiz
I don't understand what's going on here
Old Dec 18, 2012 | 10:19 AM
35thannyZowner
Old Dec 18, 2012 | 10:27 AM
35thannyZowner
Old Dec 18, 2012 | 10:51 AM
35thannyZowner
Old Dec 18, 2012 | 11:04 AM
str8dum1's Avatar
str8dum1
thats is a pretty amazing discovery!!!! I really cant believe you shared the secret with everyone. Hopefully I can go do a show at my dealer this weekend. They get pretty booked up this time of year.
Old Dec 18, 2012 | 07:10 PM
Esser's Avatar
Esser
The aftermarket air filters, and intake ducts that I have seen are located directly above the engine in the engine compartment, and are exposed to the direct heat of the engine. They also can get wet...that is why the bags that go over the filters were invented. My intake does not get wet, and it is located as originally intended forward of the engine compartment, still receiving outside fresh air. Recently I modified the air intake forward of the radiator in order to cut down on the air turbulence caused by the stock "sight shields". This helps to allow a smoother flow of air directly to the intake box, yet without any water vapor problems because of the intake box location. My hp was increased substantially.
huggz,
June
Wow! how much did it increase!?!?!
Old Dec 18, 2012 | 07:22 PM
jerryd87's Avatar
jerryd87
im betting over 9000
Old Dec 18, 2012 | 07:56 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
huggz,
June
Got some dyno sheets or videos to back up your claims of superior horsepower and super duper Lambo sound?
It sounds better...even at only 7200
A few months ago I brought the Z to the dealer. They know me well, and asked me to put on a little show. So immediately about a dozen employees stepped out side, women & men. I brought it out on the road, turned off the TDC, and stepped on it. It was very short but enough. I turned around, and went back. They couldn't believe the performance, and the sound of it. I was told that the week before a GTR owner did the same for show. I was told right then that the GTR didn't even come close to compare at all with what mine could do. The car cost me a small fortune when I bought it, but it was worth it.
huggz,
June
Old Dec 18, 2012 | 09:06 PM
bmyles's Avatar
bmyles
I looked up 35thannyZowner's other posts and, if she is telling the truth, she is 67 years old and her car has Lambo doors. I'm not sure what world she lives in that she thinks a Z compares to a GTR, but what do I know.
