Cold Air Intake Problem
Old Dec 28, 2012 | 09:35 PM
JDM_35OZ's Avatar
JDM_35OZ
Default Cold Air Intake Problem
Question part 2.
The initial problem(s) are gone now after I did the ECU reset/throttle learning procedure and what not.
NOW, when I turn the car on, the RPM's dip down to like 300 and go back to normal and it stays on and runs fine. Is this normal and is it going to go away in time?
Again, thanks to everyone on this forum who helped, I really appreciate it!
Last edited by JDM_35OZ; Dec 29, 2012 at 04:02 PM. Reason: Fixed the first issue, now this one
Old Dec 28, 2012 | 09:40 PM
Z_on_TE37's's Avatar
Z_on_TE37's
Do the ecu reset and idle air learning and throttle thingy lol, mine ran like crap when I installed my injen, I did that stuff, and it learned it quick. Just google 350z official exu reset. Hope I helped
Old Dec 29, 2012 | 12:15 AM
3508EVO's Avatar
3508EVO
You probably installed the maf sensor the other way around.
Just google images or youtube for installation of cold air intake. Hope this helps.
Old Dec 29, 2012 | 12:24 AM
JDM_35OZ's Avatar
JDM_35OZ
You can't screw in the maf sensor if its in the wrong way, just saying.
Old Dec 29, 2012 | 01:26 AM
daytonabluez05's Avatar
daytonabluez05
Did you unplug the battery when you installed it? my AEM CAI didnt have any issues when i put it on. if not do the reset like he said earlier.
Old Dec 29, 2012 | 03:07 AM
freddys 350z's Avatar
freddys 350z
make sure you installed the tube that goes to the bottom of the intake pipe.
Old Dec 29, 2012 | 05:43 AM
silvertouringz's Avatar
silvertouringz
pics?
Old Dec 29, 2012 | 09:39 AM
JDM_35OZ's Avatar
JDM_35OZ
It doesn't stay on long enough for me to try the ecu reset procedure.
Old Dec 29, 2012 | 10:03 AM
JDM_35OZ's Avatar
JDM_35OZ
Okay, I tried that last night, but I don't think it was working. Plus, my car stalls out so I can't get the rest of the ecu thing done. I left the battery disconnected overnight and it got a lot better though. Now it idles much smoother and it revs up higher but it still stalls out. Any other thing I can do?
Old Dec 29, 2012 | 10:05 AM
JDM_35OZ's Avatar
JDM_35OZ
Originally Posted by silvertouringz
pics?
Which part do you need pictures of so I can get them for you.
JDM_35OZ's Avatar
JDM_35OZ
The vacuum hose? It's on nice and tight.
Old Dec 29, 2012 | 10:49 AM
Dude1312's Avatar
Dude1312
dude i had that problem on my hr. i didnt isntall a cai tho. i had some one give me a boost right be before that happened and the mechanic said that it shorted out the throttle bodies and fudged up the ecu. thats was caused the rough idle, the car dying and it only reving up to about 3500. the mechanic replaced them and it worked fine.
Old Dec 29, 2012 | 11:53 AM
Waiz's Avatar
Waiz
Generic intake giving you problems, big surprise..
Remove it and see if the problem goes away, then buy something that was actually designed for our car in mind.
You get what you pay for
Old Dec 29, 2012 | 12:19 PM
kyle22's Avatar
kyle22
Either that^^ or sounds like its a MAF issue.
Old Dec 29, 2012 | 03:59 PM
JDM_35OZ's Avatar
JDM_35OZ
I fixed the issue, thanks though. And yeah, I will be getting a legit intake when I actually have a normal job. Not planning on blowing $300 on a intake when I'm in school lol.
Old Dec 29, 2012 | 04:02 PM
JDM_35OZ's Avatar
JDM_35OZ
Question part 2.
Old Dec 29, 2012 | 08:10 PM
Z_on_TE37's
You're welcome, like I said my car did the same thing and the ecu reset and what not fixed it. Mine kinda fluxuates at first but then its all good. Idle air learning is what fixed it. It was sucking in more air than the ecu thought and didn't know what to do lol. I hope its all good from here on.
Old Jan 2, 2013 | 06:52 PM
Steve-O Z33's Avatar
Steve-O Z33
I had the same issues after I had the intake out for something. I rushed the re-install and I left the lower vacuum hose off. After it dawned on me months later to take time to check it, THAT WAS IT!
Uriyo_
Sep 8, 2021 08:46 AM
