Nismo header independent dyno...u will be surprised
Old Jan 18, 2004 | 05:08 PM
Eagle1's Avatar
Eagle1
Originally posted by SteaminRice
Performance guys-- would you recommend cats first or headers? Congrats Daytona on the great dyno-- you got me damn near decided on doing a mod i didn't plan on!
The headers on this car are actually pretty good. My experience in doing the mods was that the high flow cats were the most significant single change to releasing more power, with the catback exhaust next. The header change was nominal gain when added to the other two, and by far the most expensive and time consuming installation of the three.
Old Jan 18, 2004 | 05:31 PM
daytona350z's Avatar
daytona350z
Originally posted by zxsaint
I'd be curious to see how hf cats would do on your setup, but I think the next move should be a crank pulley. Should put your whole curve up a notch, and you'll be probably where i'm at in terms of numbers. At $200 it's a no-brainer.
will be installing hi flow cats as soon as they get here, and maybe will go with the underdrive pulley next....but i gotta save money first...anyone in so cal interested in a detail for their cars??
Old Jan 18, 2004 | 10:34 PM
drew703's Avatar
drew703
Default Re: RT CATS
Originally posted by GATORZ
This is slightly off the thread topic. Are there still concerns about running lean with the rt cats. Want to get these but worried about the running lean thing. On the dyno above is it running rich? I thought the 12 to 13 was best.
Thanks, Dan
bump
I'm just worried/wondering about the same thing. Hoping someone can answer this, that's all
great gains on the headers btw!
-drew
Old Jan 19, 2004 | 05:21 PM
Balls's Avatar
Balls
Originally posted by Mike Wazowski
which would only benefit FI cars IMHO.
why only FI?
I don't want to hijack so I started new thread:
https://my350z.com/forum/showthread....threadid=57449
Old Jan 19, 2004 | 05:26 PM
FLY BY Z's Avatar
FLY BY Z
I don't think you really need to worry about going lean with just cats/test pipes or just a plenum. But when you combine the two I think you may run into some pingage which you don't want.
Old Jan 19, 2004 | 05:41 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
high flow cats first... much cheeper... will give close to the same power.. at half the price...
avaialbe at http://www.performancenissanparts.com
special forum price still applies...
Old Jan 19, 2004 | 07:45 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I have I/test-pipes/plenum/injen ses...and I dont get any detonation, even at really low rpm's....I run 93 oct
Old Jan 19, 2004 | 07:58 PM
failsafe's Avatar
failsafe
....for your health
I believe that the only ones that have problems with the RT cats running lean are those who had an ECU flash prior to adding the cats. This can easily be corrected by a reflash.
Old Jan 19, 2004 | 08:55 PM
rodH's Avatar
rodH
no pinging here with Test Pipes and Plenum
Old Jan 20, 2004 | 03:20 AM
FLY BY Z's Avatar
FLY BY Z
Do you two know what your AF ratios are?
Old Jan 20, 2004 | 04:48 AM
PhoenixINX's Avatar
PhoenixINX
On three cars now...
Plenum, headers, cats, and exhaust... Zero ping.
Old Jan 20, 2004 | 07:41 AM
FLY BY Z's Avatar
FLY BY Z
like i asked before, what is the AF ratio on these cars with no ECU flash.
Old Jan 20, 2004 | 07:47 AM
VandyZ's Avatar
VandyZ
Mine is between 13.1 and 13.5 the whole way. 13.3 up top >5000 RPM.
Interesting enough it has been brought to our attention by other tuners that RT cats run unusually lean . . .especially when combined with other mods. Nothing a flash cant fix, but it may start robbing power until you flash.
We have not seen this directly as most of us here run stock cats, test pipes, or Crawford cats.
Old Jan 20, 2004 | 08:49 AM
TheBigShow's Avatar
TheBigShow
i wonder if the kinetix cats have caused this at all?
Old Jan 20, 2004 | 09:41 AM
hfm's Avatar
hfm
Default Re: Nismo header independent dyno...u will be surprised
Originally posted by daytona350z
peak gain of 12.2hp and 18.5lbs of tq
Wow. Best gains I've seen for headers. In fact, even better than testpipes.
Lucky you!
Old Jan 20, 2004 | 01:53 PM
D_Nyholm's Avatar
D_Nyholm
Those are some great numbers. I haven't seen anything like that yet with those headers!!!
Old Jan 20, 2004 | 01:57 PM
daytona350z
Default Re: Re: Nismo header independent dyno...u will be surprised
Lucky you!
thanks and at the price including install, i happy with the gains...now i want more
Old Jan 20, 2004 | 03:48 PM
  #38
TheBigShow's Avatar
TheBigShow
yeah, i'll b interested in seein if u get gains from other exhaust mods that should reduce the back pressure. like it was said before, mayb u won't see much if the nismo headers r designed for use with some. we shall see.
Old Jan 20, 2004 | 04:24 PM
  #39
sith's Avatar
sith
I have lsd test-pipes, crawford plenum, and Injen SES exhaust and i have had Zero ping aswell.
Old Jan 20, 2004 | 05:08 PM
  #40
VQ35DES's Avatar
VQ35DES
daytona, hows it sound?
