Greddy Rattle!
Old Feb 4, 2013 | 05:39 PM
SCHISANO's Avatar
SCHISANO
Default Greddy Rattle!
What causing this rattle sound. Any help or suggestions?!
Old Feb 5, 2013 | 04:18 PM
Surg's Avatar
Surg
I have the same sound different set-up, let me wait and see if someone knows.
I took of the brace for the cats because at the muffler shop they said that it cracks them. It was no problem for a while now that noise is getting worse.
Also my test pipes have no connector for the brace. Someone on this site had
a good answer as he bought some rubber exhaust holders at pepboys and I think he put on the brace and use them to wrap around the test-pipes to hold them without metal to metal contact. Did you remove your brace for test-pipes?
I am also trying to figure out this rattle. Will wait for some input because I will be out of town a couple days then I will check back later. Let me know if this provided any clue.
Old Feb 5, 2013 | 04:38 PM
nismonian's Avatar
nismonian
my motordyne rattles like crazy, since day 1. hangs too low.
you prolly have the same issue.
Old Feb 5, 2013 | 04:45 PM
Surg's Avatar
Surg
I just used the search function and discovered that on the passenger side some testpipes rub onto the heat shield as it sounds like a metal to metal contact. On the weekend Im going to try the brace reattachment with rubber hangers and see if their if I can remove the heatshield or bend it out and use the hangars to pull the test pipe away. I feel this might be the answer I will know later after I do this.
Old Feb 5, 2013 | 06:02 PM
SCHISANO's Avatar
SCHISANO
Thanks! yeah let me know how it goes im bringing mine in tomorrow to get looked at ill update if they can diagnose the problem
Old Feb 8, 2013 | 03:54 PM
Surg's Avatar
Surg
Ok I will let me know what you came up with as well.
Old Feb 9, 2013 | 12:11 PM
SCHISANO's Avatar
SCHISANO
guy said it was a loose upstream o2 sensor. the rattle seemed to go away ill keep you posted to see if the problem is fixed permanently
Old Feb 9, 2013 | 12:58 PM
Surg's Avatar
Surg
Oh ok I will have to take it somewhere I took of the heat shield but it is still there. Tapping on the test pipe I can definately hear something loose on the passenger side one the other is tight. So maybe it is a loose o2 sensor or the resonator inside the pipe is loose but I think it should be narrowed down to that.
Glad to see you got it fixed Im going to take it to my muffler guy and let them do it.
sales@czp
Sep 23, 2019 03:30 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
