Heat Shields and Kinetix HFC ?
Old Sep 7, 2013 | 06:24 AM
04DaytonaZee's Avatar
04DaytonaZee
Default Heat Shields and Kinetix HFC ?
Hey guys,
Do I need to run the floor pan heat shields with the Kinetix HFC? I pulled the heat shields off while installing the Kinetix because they were pressed up against the shields pretty good. Now the floor pan of the vehicle and underneath the vehicle obviously gets pretty hot while driving
Do I need to re install them? Will it cause damage / has anyone else had experience with this? I don't see a way I can bend the driver side heat shield more than a 1/4" which may or may not give sufficient clearance from the cat.
Old Sep 7, 2013 | 12:58 PM
Squag27's Avatar
Squag27
+1 I installed the same cats a week ago and had been having the same fitment issue with the shields, rubbing on the driver's side and barely clearing the left. I flattened the driver's shield a bit and it clears but JUST barely.
Old Sep 9, 2013 | 04:12 PM
04DaytonaZee
I re installed the heat shields and bent them back about 1/4" as well. Works, but barely. Sucks. My new issue now is the damn vibration with the Kinetix HFC and Nismo Y-pipe on deceleration. It's terrible - the body of the vehicle vibrates around 2,500 rpm.
EnjukuRacing
Sep 30, 2015 06:55 AM
Obeorangekenobi
Sep 11, 2015 07:17 AM
juang20
Intake
Sep 7, 2015 05:37 PM
