ART Pipe Questions and Issues
Old Jan 23, 2014 | 08:26 PM
  #41
Waiz's Avatar
Waiz
I think 3 threads for the same topic is overkill OP so your threads have been merged....
Obviously something wasn't installed correctly, recheck all your bolts and I would bet it's the heat shield
Old Jan 23, 2014 | 10:02 PM
  #42
Lonestarr350's Avatar
Lonestarr350
Yeah my bad 😫 .. Won't happen again!
Old Jan 24, 2014 | 03:02 AM
  #43
travlee's Avatar
travlee
Master
Originally Posted by Lonestarr350
I still can't pin point that ANNOYING buzzin sounds wit my art pipes ... I checked the bolt on the driver side .. It was shaved enough .. So I tried check the heat shield and it doesn't seem to be touchin the pipe !!! Wtf !!! If anyone can maybe post a pic or somethin of where the buzzin is comin from is really appriciate it !! Cuz I'm annoyed and I've only had the pipes in for 2 days !!
just turn up the radio, it doesnt have to be touching the heatsheild, just close to it and it will make it rattle some from the pulses of the exhaust
Old Jan 24, 2014 | 07:14 AM
  #44
RUNWDVL's Avatar
RUNWDVL
With my motordyne overkill. I don't think it's an issue. If your car is sputtering or something then you have a problem.
Old Jan 26, 2014 | 10:19 PM
  #45
Lonestarr350
Default I hope it's nothing serious .......
Just about a week ago I installed art pipes on my 07 z .. One thing I came across after installing them .. Even after my engine is warm ... I feel like when I shift to 2nd or 3rd gear it doesn't "catch" it right away like it hesitates a bit. I'm not sure if it has to do with the pipes? ( it didn't do it before until now ) .. Or maybe it's something else ? Plz help !!! 😣😣
Old Jan 26, 2014 | 10:20 PM
  #46
Lonestarr350
Maybe it's my o2 sensors ? Idk but I wanna get this resolved ASAP!
Old Jan 26, 2014 | 10:29 PM
  #47
Lonestarr350
What exactly do you mean by sputtering ?
Old Jan 26, 2014 | 10:40 PM
  #48
winchman's Avatar
winchman
The first thing to try is removing the stupid pipes.
Old Jan 27, 2014 | 01:39 AM
  #49
travlee's Avatar
travlee
Master
misfiring, running bad.... etc
Old Jan 27, 2014 | 05:39 AM
  #50
JERZ350's Avatar
JERZ350
Try an ECU reset?
Old Jan 27, 2014 | 06:02 AM
  #51
Deteria's Avatar
Deteria
The best thing you can do is get an UpRev tune. Most likely your car is running lean after the art pipes and that hesitation you feel is your engine not getting enough fuel in a certain rpm range. Correcting your AFR will also reduce your risk/chance of getting a CEL. It is pricey, but get it done and side bonus of tune = more power as well
Old Jan 27, 2014 | 06:48 AM
  #52
travlee's Avatar
travlee
Master
why do you think they are stupid?
i agree, it didnt do it when i had my gemini exhaust but when i swapped to the motordyne tdx2 i had hesitation... i was really lean, after a re-tune it went away
Old Jan 27, 2014 | 09:22 AM
  #53
Lonestarr350
Thanks man! I appriciate the help !!!
Old Jan 27, 2014 | 01:41 PM
  #54
08andawesome's Avatar
08andawesome
Do you make a new thread about this crap every 20 min? Just take the damn things off!
Old Jan 27, 2014 | 02:21 PM
  #55
Sick an Twsd's Avatar
Sick an Twsd
OP, when you installed them did you let your ECU reset? take your battery batter cables off for the night, push the brake pedal in, let it sit over night, plug everything back in before you go to work or something and then drive normally, not like a bat out of hell, normal haha
Old Jan 28, 2014 | 03:48 AM
  #56
travlee's Avatar
travlee
Master
if you paid the 500+ dollars for them you wouldnt want to take them off... why dont you post something useful instead of being an idiot
Old Jan 28, 2014 | 06:00 AM
  #57
Deteria's Avatar
Deteria
Lol my 1st performance mod was actually TDX2, then I got the ART pipes afterwards. But fairly certain a tune will solve your issues. I didn't really do an ECU reset. Basically the factory ECU can't adjust to optimal settings anyways, so it causes the lean spot/power loss.
Personally I'd get an exhaust before you go tune since you'd have to re-tune afterward (extra cost). Soooo much $$$$$$$$$
davidm350
Oct 31, 2015 02:28 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
FromGtoZ
Sep 20, 2015 03:41 PM
