HR Manifold
Old Jan 27, 2014 | 05:39 PM
alannc24's Avatar
alannc24
Default HR Manifold
so I know this has been posted for, please do not tell me to search. I've googled motordyne intake manifold, revshift, and literally every link does not have the manifold. i also used the search bar up top, and every link is empty, same as google. just looking for some halp
Old Jan 27, 2014 | 07:19 PM
secwind's Avatar
secwind
There isn't one.
Old Jan 27, 2014 | 07:55 PM
KingBaby's Avatar
KingBaby
Hardest Setting
doesn't exist...
Do you need more halp?
Old Jan 28, 2014 | 02:32 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Dam you NC and your cheap prices on Zs
Old Jan 28, 2014 | 03:05 AM
travlee's Avatar
travlee
Master
Originally Posted by secwind
There isn't one.
guess he either didnt do homework, or cant read
Old Jan 28, 2014 | 05:23 AM
lifekenophobic's Avatar
lifekenophobic
I hear this mod goes perfectly with one of those HR plenum spacers.
Old Jan 28, 2014 | 08:17 AM
Ser_Z's Avatar
Ser_Z
http://www.motordyneengineering.com/...649575a58c884f
Look there I think this is the item you're looking for?
http://www.motordyneengineering.com/...?pID=7&image=0
350Z MREV 2 Manifold TM $509.25
MREV 2 Manifold TM - The most powerful naturally aspirated bolt on you can put on your revup engine.
When used with or without a spacer or aftermarket upper plenum, this lower plenum will make substantial power gains. Multiple independent test show when used with a 5/16" spacer on the revup engine, the combination will add a "minimum" of 15+ HP and 18+ TQ in the upper midrange. Many independent MREV 2 Manifold REVUP tests have dynod in excess of 20HP and 30 TQ in the upper midrange and with high RPM peak power increased by 3-5 HP.
The MREV2 is a prerequisite to the plenum spacer when used on a revup engine. No other normally aspirated VQ modification provides as much gain as the MREV 2 Manifold!
Independent dyno test on the Revup engine.
Independent dyno test on the Non-Revup engine.
Installation Tips
Note: MREV2's are made from non-revup core exchanges. Motordyne will buy your non-revup lower plenum. Contact us for more information.
Old Jan 28, 2014 | 08:34 AM
travlee's Avatar
travlee
Master
Installation Tips
read the title... it says HR manifold... not revup, so he cannot do plenum spacers or manifold.......smh
Old Jan 28, 2014 | 09:04 AM
sradenton's Avatar
sradenton
Installation Tips
Old Jan 28, 2014 | 07:31 PM
Ser_Z's Avatar
Ser_Z
sh__t....you're right.
_koubie_
Sep 20, 2015 06:34 PM
