Do any HFCs or TPs not crack with S-Tune?
Old Jun 20, 2014 | 04:02 AM
SQuaLZ's Avatar
SQuaLZ
Default Do any HFCs or TPs not crack with S-Tune?
Hello all. Now that my warranty is up on my car I wanted to maybe change out the cats on my Z.
I have the S-Tune exhaust and after doing a bunch of research I have found that most HFCs and TPs will crack when paired with the S-Tune, or the Y-pipe will crack. I definitely do not want to risk breaking my exhaust for a few extra hp, but was wondering if a certain brand works with the S-Tune.
I would prefer a HFC to a TP as my last car had a TP and the smell got annoying over time.
Also, apparently Nissan changed the S-Tune at some point to strengthen it due to this type of cracking. Not sure if it is true but I bought my exhaust new from the dealership around the end of 2010.
Any help would be appreciated.
Old Jun 20, 2014 | 04:13 AM
travlee's Avatar
travlee
Master
i would look into something that has the brackets for oem cat brace. i had the kinetix cats and they didnt have them and i cracked a cat. i guess worst case scenario you could have a shop weld tabs on the cat or TP.
Old Jun 20, 2014 | 04:21 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
In theory, I would think Megan's resonated test pipes would work since they have a flex joint on them.
Old Jun 21, 2014 | 08:15 AM
SQuaLZ's Avatar
SQuaLZ
The brackets do seem very important so if I do get something I will make sure they have brackets.
I don't think I would ever get Megan products. Even when I had my Civic I refused, so I would definitley not put that on my Z. Any other companies make it with flex joints?
Old Jun 21, 2014 | 08:20 AM
Bmurray350z's Avatar
Bmurray350z
Just look for some that have flex pipes in them. You should be good then.
edit - just looked through CZP's exhaust section, and i dont see any HFCs with a flex joint. Only test pipes.
Old Jun 21, 2014 | 06:21 PM
SQuaLZ's Avatar
SQuaLZ
I might be blind but I did not see any test pipes with flex joints on CZP. I might consider test pipes but I am wary of the rasp and also the smell.
Old Jun 21, 2014 | 06:32 PM
Suwaidi's Avatar
Suwaidi
The smell isn't as bad as you would think. If you're driving aggressively with your windows down, you might catch a whiff coming to a stop. Otherwise, you will barely notice it.
Old Jun 21, 2014 | 06:36 PM
SQuaLZ's Avatar
SQuaLZ
My Civic was pretty bad, but probably worse since I needed a tune as I was running pretty rich when it was boosted. My B13 has no cat and it is also pretty bad. That car stinks!
Old Jun 21, 2014 | 07:02 PM
Suwaidi's Avatar
Suwaidi
With the ART pipes, I barely noticed the smell, if anything it would be one in 100 drives where I would smell it.
On a side note, the ART's got me +8.17whp, +11.59tq, two runs with rather similar conditions on the same dyno.
Old Jun 21, 2014 | 07:31 PM
Bmurray350z
I don't notice any smell at all. However I have been driving a Z with test pipes for the past 4 years lol. So I'm extremely used to it.
Old Jul 22, 2014 | 01:05 PM
SQuaLZ's Avatar
SQuaLZ
So Megan is the only company to make TPs with flex pipes? If a better company made them I would buy them in a heartbeat. Any other company makes them with the flex pipes that I am missing? Decided I would go for test pipes over HFCs.
Old Jul 22, 2014 | 01:12 PM
meanz's Avatar
meanz
Megan test pipes with the flex joint are still garbage. Both of my test pipes were cracked all the way around. One was even welded before. I'll try to dig up a picture.
Old Jul 22, 2014 | 04:06 PM
meanz's Avatar
meanz
Old Jul 22, 2014 | 06:26 PM
travlee's Avatar
travlee
Master
squalz.... do the ART pipes. I cracked a Kinetix HFC, and i have yet to have a problem with my ARTs
Old Jul 22, 2014 | 06:30 PM
SQuaLZ's Avatar
SQuaLZ
Are you running the s-tune y? How long have you been on this setup? Thanks if ARTs work I would love that since I have read such good things.
Old Jul 22, 2014 | 06:33 PM
travlee's Avatar
travlee
Master
no sir, i am motordyne all the way. but i do have a buddy that has the s tune with kinetix cats and he has never had a problem. i think the s tune with ART would sound amazing though.
Old Aug 10, 2014 | 06:57 AM
Bigsyke's Avatar
Bigsyke
In theory it sounds good, but having 4 flex pipe sections make your exhaust flap around under the car doing more damage to the pipes as they eventually shake themselves to death.
I really do not understand why the Z33 likes to break exhausts. My Z32TT has NO play in the exhaust with 0 flex sections anywhere. 0 leaks for about 6 years.
Old Aug 14, 2014 | 05:38 PM
Andrei's Avatar
Andrei
Actually putting the windows down creates a vacuum in any car and air comes into the cabin from the cabin vents inside the quarter panels, and the exhaust gas usually gets temporarily trapped at the back of the car and gets sucked in through those vents. This is a problem on the 03-06 G35 sedan since the cabin vents are located at the very bottom of the quarter panels because the bumper doesn't cut all the way to the fender wells to allow those vents to be placed midway inside the quarter panel, like it is on every other car. It is also a problem that the EVAP canister is next to the right/passenger cabin vent, though that was not a problem on my 04 G35 sedan and that car had pristine cabin air quality. The diffuser for the Evap canister actually has a hole in front to scoop air and one in the rear to shoot out the vapors not caught by the canister... lawsuit..
Leave the cats on, unless the car burns oil. Did anyone see the tolerances between the oil rings and cylinder walls in the FSM? The pistons are cast and they expand pushing the rings against the walls causing them to wear prematurely, especially true since the VQ is prone to heat soak because in Japan they hate cold-start emissions - I did not know this until I saw it happen and ran without a t-stat in the summers. They changed the casting process on the HR and VHR so oil consumption is not as common. But this is problem for Toyota and even Honda, though they will never admit it.
You can see here how exhaust gets trapped at the back of almost any car. http://www.gtrblog.com/wp-content/up...tr35-2-010.jpg Probably not a good idea to sue the EPA.
Old Aug 14, 2014 | 10:15 PM
.cakestar's Avatar
.cakestar
you should ditch the stune y-pipe. the shape and style is the same as the old de y-pipes just larger diameter which are inferior. get an xyz pipe or if you want it more muted just go with the hr y-pipe. you will get some hp as well as not have to worry about cracking test pipes / cats
norrix420
350Z Roadster
May 23, 2022 05:11 PM
Twenty4
Jan 17, 2016 01:20 PM
nanotech
Oct 2, 2015 05:02 AM
