Those with Nismo headers - passing smog?
Old Feb 23, 2004 | 01:37 PM
drew703's Avatar
drew703
Default Those with Nismo headers - passing smog?
Sorry for the newbie question, but I've seen and read that headers will not pass the "sniffer". Does this apply to all aftermarket headers, Nismo specifically?
If this is the case, (again sorry for newbie question!) but what happens exactly when you dont pass emissions? I dont have aftermarket headers yet, so I just want to know what some of this modding is going to entail
-drew
Old Feb 23, 2004 | 05:50 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
if you have the stock cats and the headers.. you will have no problem.. they are next to imposible to see so no worries on a visual..
Old Feb 23, 2004 | 06:01 PM
drew703's Avatar
drew703
Default alright...
but as of now I'm planning on going with Hi flow cats and most likely Nismo headers...so what exactly is gonna happen when I go try and pass emissions and I dont?
Well I think I just realized the answer to my own questions, but for all the owners with mods that would normally FAIL emissions, is the way around it just to basically "revert" your Z almost back to stock form (at least enough to pass emissions) then go and put back the headers, hi flow cats, etc??
sorry, just trying to get an understanding of all this
-drew
Old Feb 23, 2004 | 06:34 PM
Jason@Performance
Performance Nissan
well.. check your local laws...
see if you can change the cats on an OBDII vehical in your state..
the RT Cats are C.A.R.B. Approved and pass smog on the sniffer.. but.. if you get a visual and they see they are not stock cats (very hard to see) they will ask if they are carb certified if you are alowed to change cats.. if not.. well then..
and the cats are easy enough to change back to stock.. and alot less then a fine if you do it bbefore you get smoged
Old Feb 23, 2004 | 06:43 PM
flynnibus's Avatar
flynnibus
Z Flier
look at maryland's websites about it. Emissions in Maryland tend to be pretty weak.. they aren't even that old.
Maryland also uses the ORB port and on some cars doesn't even use the 'sniffer', they just tap into what the computer says.
VA uses both a visual and sniffer test and runs more often (every 2 years).
Old Feb 23, 2004 | 09:16 PM
drew703's Avatar
drew703
Thanks guys
Old Feb 24, 2004 | 04:48 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
My car passes the "sniffer" with Cams, Cats, Headers, Ported Heads....etc... These cars just run clean!
ablaine
Nov 29, 2016 10:13 AM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
