Whats the going prices on most Y-pipes?
Get the JIC!!! It looks sooo good compaired to others.. I believe its 480$ from Performance Nissan.. Hey Jason do I smell a group buy
Iv been seeing a lot of intrest in the JIC Y-Pipe if you know what i mean lol
heres another y-pipe (a little cheaper)
https://my350z.com/forum/showthread....threadid=26180
geez...... i want to change my ypipe too. hmmm... kinetix plenum, ypipe (japtrix or JIC), or hotchkis sways??? so many mods.... so little money.
Originally posted by Ultimateone
I mighth be doing a Y-pipe soon or the plenum. What are the average prices for y-pipes
Interested.
Originally posted by infidsg35
Ok how about this.. If you read this and might be interested in a group buy of a JIC Y-Pipe post here so maybe we can show enough interest and actually get one going!!!
Sweet.. The Y - Pipe will bolt on to the OEM exhaust. It will give you 80% of the HP that a cat back exhaust would give you. It should be good for 5-6 HP
GROUP BUY!!!!!!!
GROUP BUY!!!!!!!
If you want the benefits of the Jic Y-pipe, it's important to realize hooking it's 80mm collector/flange up to the oem's 65mm mid pipe will create havoc to the exhaust flow at that point and negate what may be expensive stuff upstream. The Jic Y-pipe is ment to hook up to a 80mm system down stream. Here's what I mean, I happen to have a Y-collector that collect's to a 80mm pipe diameter with a 65mm flange welded to it. When you look inside of it you can plainly see about a 1/4" ridge directly in the flow path at the 80mm to 65mm transition. But, their is a easy solution if your bent on using the Jic Y-pipe on your oem system, or aftermarket system that use's a like 65mm mid pipe diameter, more in a little bit.
Look into the pipe in this pic, you can see the lip at the other end at the flange, 80mm to 65mm
Notice the collector diameter of 80mm
And the 65mm diameter of the flange.
Ok, your easy solution is to have a muffler shop splice in a smooth transition tube ($30 part + $5 for a 80mm flange) onto the end of your mid pipe. Here's a link to what I'm talking about.
http://www.burnsstainless.com/Transi...ansitions.html
Part # RD-250 would be perfect.
Well if I got the JIC it would be perfect because my midpipe back to my HKS is 3"
Get the Jic Y-pipe. Don't make me post pics of what the oem Y-pipe looks like under it's heat shields.
Bad very very bad.
Oh, your trying to decide between the Y-pipe or the pleneum. Ok, well that's a tuff one. I got great gains from my Crawford pleneum. But then again, same thing with my header back exhaust system. Tuff choice, I'll give ya that.
If you add that converter then it would make it 2 inches longer right?? Then that will effect the rest of the exhaust. Or would you cut the 2 inches off the oem's mid pipe? Wait now that I think about it you would have to cut both the JIC an the OEM one in order for that piece to fit... Im not down with that.. Plus big to small is not what I want to do.... Well I know Performance nissan might put the JIC in with the Nismo exhaust as a package.... Bahhhhhh I was misinformed!!!
I got the Japtrix Y and Mid, and numeric results are in.
In a recent head-to-head dyno testing day, my simple Y and mid outperformed Stillen duals, at a much lower cost.
Japtrix Info :
Japtrix Y and Mid pipe
The Dyno results :
SFZCC Dyno Day
Fits perfect to the OEM cats and muffler. Easy bolt on. The guys at Japtrix installed it for me in 10 minutes or less.
Noise level is minimal. You get a raspy note at about 4500 rpm that sound very cool. I didn't want more noise, just some power.
Japtrix Info :
The Dyno results :
SFZCC Dyno Day
Does the JIC bolt right up to the OEM sizing?
Yes, the Jic's 80mm collector flange will bolt up to the oem systems smaller 65mm flange. That is why I did the above post pointing out what will happen to the exhaust flow at that point.
