SSR Engineering Intake Manifold Complete! *Pics*
Old Jun 5, 2004 | 10:56 PM
  #121
supra crazy's Avatar
supra crazy
Bump
and does any one know what happend to this manifold is lsd still gonna make it?
It allows you to keep the engine cover and strut brace
Old Jun 5, 2004 | 10:58 PM
  #122
supra crazy
and this
Attached Thumbnails SSR Engineering Intake Manifold Complete! *Pics*-manifold35.jpg
Old Jun 5, 2004 | 11:01 PM
  #123
supra crazy
Originally posted by supra crazy
and this
Attached Thumbnails SSR Engineering Intake Manifold Complete! *Pics*-manifold11.jpg
Old Jun 6, 2004 | 12:18 AM
  #124
adrianko43's Avatar
adrianko43
who makes that? they look awesome
Old Jun 6, 2004 | 04:41 AM
  #125
12SecZ's Avatar
12SecZ
The last two was to be LSD's aka Kinetix plenum a Top Secret type design which I really wanted bad but it never was produced that I know of. It was to be forced induction only IIRC.
Old Jun 6, 2004 | 06:46 AM
  #126
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Max: I like the look of that one just above that retains the stock strut and engine cover. Do you know anything else about it? HP gains?
Old Jun 6, 2004 | 03:04 PM
  #127
12SecZ's Avatar
12SecZ
I first saw the design here http://www.topsecretjpn.com/topsecretenglish.html
They wouldn't post any numbers or sell just the plenumit is part of their turbo package. LSD was working on one but the demand was higher for his N/A model so he focused on that. I never heard any further after that.
Check out this hood though
http://www.topsecretjpn.com/topsecretjapanese.html
Old Jun 7, 2004 | 03:56 AM
  #128
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Thanks
Old Aug 15, 2004 | 11:15 PM
  #129
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally posted by karlhungus
It will be a pig under 4K, the ECU will try to vary the cam timing but will just be all confused. I would expect the dyno and A/F to be very choppy. Above 4K you should see things smooth out and actually see 15-20 HP gains at redline, but HUGE torque loss down low. This is drapstrip manifold, a tunnelram. Not a streetable mod.
Karlhungus,
I am not questioning your conclusion, you called it correctly, SSR verified this to me over the phone last week, but how did you come to this conclusion? You have a lot of predictions in your post. How did you conclude this by observing the pictures?
I was think of building an intake plenum of my own just for experimentation purposes but before I spend the time and effort I would like to learn as much as possible from others before trying. I want to increase my odds of making a successful mod.
Tony
Old Dec 17, 2004 | 02:52 AM
  #130
karlhungus's Avatar
karlhungus
Originally posted by Hydrazine
Karlhungus,
Tony
Tony,
Sorry it took so long to reply, I haven't visited this site in a while. Anyway, it is pretty common knowledge that short runners on an intake shift the power curve to the higher RPM band and result in a loss of low end torque. Thats why I called it a dragstrip manifold, since it would only be of benefit at full throttle with a manual transmission or a high stall RPM auto.
People underestimate how complex intake design is. Bigger plenums, shorter/more direct paths for "more air" does not necessarily mean more power. That's why the whole Crawford plenum is a joke too. A couple of guys with a flow bench and a welding torch have not outsmarted the Nissan engineering dept. Static flow through a plenum on a bench does not account for the dynamic pressure waves and harmonics in the intake caused by the intake valves opening/closing 10 times/second. Thats why the whole intake is "tuned" to a particular frequency with the intake trumpets under the upper plenum and a specific tube length. The flow of air into a VQ35 cylinder is not limited by the plenum. The engine only requires about 400 CFM of flow at redline and the stock intake is more than capable of that. The real restriction is getting past the heads and valves.
My advice is to not concentrate on the plenum at all. If you plan on staying N/A, go with the cams, heads, and exhaust (catback with highflow cats or testpipes). Then have technosquare optimize your mix and timing. I dont know if those guys know what they are doing with cam timing, but these are serious mods and you dont want some jokers playing with your code.
I just have a K/N drop-in filter, z-tube, stillen catback, and a UR pulley set on my G35 and they work good together. I dont plan on doing any more to it. My new toy is fast enough. Good luck with your projects.
Attached Thumbnails SSR Engineering Intake Manifold Complete! *Pics*-galaxyblue1.jpg
Old Dec 17, 2004 | 03:29 AM
  #131
ZinMiami's Avatar
ZinMiami
Hey Tony, just being devils advocate here, but how do you account for folks that have put in say a Kinetix or Crawford plenum and then had Dyno's that show legitimate HP & torque improvements?
I do agree right off that I too wonder if it's possible that Nissan could have really messed up the design of the stock plenum so badly. But I also understand that manufacturers are driven by many factors and not necessarily performance or best possible design. Although if they did make everything perfect there would be no aftermarket!
Old Dec 17, 2004 | 05:26 AM
  #132
karlhungus's Avatar
karlhungus
When I first got the Crawford in the mail, I thought it was a cut and paste piece of crap. But I put it on anyway just to verify if the hype and the overall concept was correct. It wasnt. On my car, I showed a 7 HP loss and a BIG 12 TQ loss. I dont have the time or energy right now to seach posts, but I remember others posting here with the same results and then others seeing actual track times worsen after a plenum or CAI install. The ECU is pretty smart and it doesnt like its world being messed with. It is constantly checking air temp, manifold vacuum, flow, knock, throttle position, and god knows what else to determine cam/ignition timing. Change the dynamics of the plenum and things can get kinda messy.
Old Dec 17, 2004 | 06:30 AM
  #133
VandyZ's Avatar
VandyZ
karlhungus,
Sorry you had problems. Could you show the dyno charts? Did you make any other changes between dynos? Did you redyno after you removed the plenum to make sure it was the culprit? What did you do with the plenum? We have never seen losses like that due to the plenum addition. I suspect other issues. We have seen little to no gains due to other issues, but those are usually resolved with tuning.
I dont know how to say this without sounding arrogant, but I am gonna anyway. In no way have you given this board enough proof through 21 posts that you are an authoritative figure in R&D, testing, and tuning the 3.5L VQ. You might be, but I dont know. Making blanket statement such as you have does throw up red flags in my mind.
You are right in the intake design is very intricate and particular. I cant stress how much knowledge went into the design. I also cant stress how many times we have questioned a Nissan engineered spec so don’t always assume that Nissan has thought of everything. The plenum is a prime example. Yes the lower intake (w/ runners) was designed very well. We have tried and failed to alter that piece to make power. The upper piece however was compromised due to the marketing dept stressed for the need of a strut bar (Nissan confirmed). Then the penny pinchers decided it would be better to make one plenum for the half million units (RWD VQ35) per year than just giving the Z its own (assumption), thus being used on other infiniti / nissan vehicles.
Any way good luck with the Z and the bike.
Old Dec 17, 2004 | 08:02 AM
  #134
karlhungus's Avatar
karlhungus
Sorry if I sounded arrogant. It was early in the morning and I am a grouch about then. All I posted was my experience and opinions. People can take them or leave them.
On the other hand, it's great that there are people that work to improve upon OEM designs, but with the complexity of modern engines, getting any significant gains with N/A mods is getting really tough.
I will try to find the disc with the dyno runs and post them.
Old Dec 17, 2004 | 11:10 AM
  #135
SSR Engineering's Avatar
SSR Engineering
Hey guys, most of you are anxious on getting those dyno numbers out! Well there's good news we are going to release the dyno numbers next week. At this time we are only going to be advertising this as an F/I related product, until we finish testing it on our N/A car as well.
I will post the dyno charts next week.
Old Dec 23, 2004 | 08:45 PM
  #136
Hydrazine's Avatar
Hydrazine
Thumbs down Next Week My Azz
SSR ENGINEERING
Next week my Azz. Please shut the F*** up about next week.... You've been spewing about "NEXT WEEK" since March 2004. NEXT WEEK is nothing but a bald faced lie.
You already have the graph but wont post it because it looks like In fact, you probably just keep talking about it to get visits to your website.
Just post a bogus graph already and we wont have to keep hearing about NEXT WEEK.
Old Dec 24, 2004 | 02:20 AM
  #137
aalzuhair's Avatar
aalzuhair
Is it about next week now... Anyway, post the dyno when you can
Az
Old Dec 24, 2004 | 04:20 AM
  #138
dansouliere's Avatar
dansouliere
Thread started on March 25th 2004 and we are December 24th 2004.
Next week
Old Dec 24, 2004 | 04:36 AM
  #139
booger's Avatar
booger
SGP has a G35 on there web site that they installed aTT on . It has the coffin plenum on it . It made big numbers when SGP got done tuning it . But dont think it will do much for N/A or a SC car . Short runners on the intake ...from what I unerstand ...dont do well for trq down low . The Kinetix split intake looks more promissing . It also looks like it could use a little cleaning up and smoothing around the edges to make it look better
Old Dec 24, 2004 | 09:11 AM
  #140
johanna1's Avatar
johanna1
SGP told me it would not be worth it to buy it. They said it would be better to buy a plenum instead. It sounded like he was trying to warn me about something, maybe that it is a waste of metal. I like the kintex one through, but will have to see if it proves to be worth it. APS for now.
