Which is the best exhaust system?
Old May 20, 2004 | 10:54 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Originally posted by ares
love my injen. but as jason said, Id bet 20bucks performance wise no one on this entire forum or in the world could tel the difference on a performance basis
now soun and appearance is where you should make your choice. might sound bad to choose disregaurding performance, but its all the same for power.
TRUE!
Exhaust is what I like to call a "SMILE" mod... Biggest difference is in sound and look... do not get an exhaust and expect to be smoking m3's into your rear view...
ooooh i gotta story to tell... look for a thread in engine/drivetrain/fi... hehehe
Old May 21, 2004 | 02:59 AM
picass's Avatar
picass
Default Ask
Originally posted by Jason@Performance
TRUE!
Jason, what is the diameter in mm. of the different exhaust in the central pipe?? 76mm in the Nismo don't is more larger??
Old May 21, 2004 | 01:16 PM
webcarconnection's Avatar
webcarconnection
OMG Greddy EVO 2 all the way
Old May 21, 2004 | 08:26 PM
Jason@Performance
Performance Nissan
I will find out this weekend when I am back in the office... I was in the office for 5 hours today so didnt have much time... I am usually there 12-14 hours so have more time to get things done... but not enough ttime still
I like the greddy EVO-2 as well.. too bad I cant keep them in stock....
oh and if who ever text messaged me about the TANABE exhaust to my cell phone... I can only read text messages and do not see who sent it so please PM me...
Old May 22, 2004 | 06:09 PM
zoham55's Avatar
zoham55
Thanks for all the info Jason. So you would still say that the Tanabe with Fujitsubo Y pipe is the best right?
Old May 22, 2004 | 10:32 PM
Jason@Performance
Performance Nissan
Is the best for a high powered NA car... by high powered I mean already running or planning to run headers / high flow cats or test pipes... as well as posibly cams...
if you do not plan on changing to high flow cats or headers... then the injen will yeld the most power on a NA car...
this is what I have found with the exhausts that are out to this date...
Old May 23, 2004 | 01:11 AM
o snap its eric's Avatar
o snap its eric
Actually, believe it or not but i can definitly feel the difference in my Nismo ezxhuast above 3.5+rpm. I can actually chirp 3rd gear now. Before i can only do second gear.
Old May 23, 2004 | 01:14 AM
Jason@Performance
Performance Nissan
there is a difference in power.... it is just not an obvious power increase but it is felt...
Old May 23, 2004 | 08:35 AM
zoham55's Avatar
zoham55
What is a good exhaust to get if I am planning on going FI??
Old May 23, 2004 | 11:33 AM
Jason@Performance
Performance Nissan
One with large diamater piping...
If you are looking for one with a SINGLE muffler and 2 exit tips (stock look) the NISMO S-Tune exhaust will be the one with the largest diamater piping in that class...
If you are looking for one with 2 seperate canisters then you have a few options... Tanabe with either the Fujitsubo or JIC Y-Pipe, Greddy Evo-2, Apexi N1...
The INJEN would work but the piping isnt large enough IMHO...
the Invidia / RS-R are nice but the piping isnt as large as the tanabe in th emid pipe and where the pipes split is not as smooth like where the tanabe splits...
no matter what exhaust you put on, you are going to get good performance out of a turbo / supercharged car.. but... keep in mind that the stock catalytic converters will steel 30-45 RWHP of what you could be getting...
we put RT High Flow Cats onto a car making 330 to the wheels with a procharger... after the cats were installed... over 380
Old May 23, 2004 | 01:12 PM
little_rod's Avatar
little_rod
I have often wondered where the real bottleneck is, the stock cats or exhaust. On a car with FI, you hate to have to spend the extra $1500 on exhaust and cats, the cats would be the cheaper option of course. With there not being much there in respect to gains for the total exhaust system, a place to keep your stock parts intact has to be known. Which one is best to keep, stock cats or exhaust for FI??
Old May 23, 2004 | 02:05 PM
Gsedan35's Avatar
Gsedan35
Here's a pic of the oem Y-pipe with the heat shield removed (close-up). Notice the deep crush bends and the awful Y collector.
Whatever anyone does, do make sure what to get rid of the oem Y-pipe.
*edit* [img] tagging not working for some reason
Old May 23, 2004 | 03:07 PM
sux2bu's Avatar
sux2bu
Jason (or other mod gurus),
So based on this and many other threads i have read, it seems that the oem y-pipe is the most restrictive section of the stock exhaust.
Therefore, I would like to know if their is an aftermarket y-pipe that will mate perfectly to the stock exhaust (fyi - g35 coupe). I have been told that the two most popular aftermarket y-pipes (fujitsubo & JIC) will not mate properly as they have a 80mm collector and the stock exhaust has a 65 mm collector. So in essence, if I was to replace my stock oem y-pipe w/ the fujitsubo y-pipe then I would also have to purchase the fujitsubo exhaust to suffice compatability of y-pipe to exhaust. Is this correct?
Old May 23, 2004 | 04:32 PM
vze4fhpv's Avatar
vze4fhpv
I may be new here but I'm thinking about a Stillen System using Stillen Test Pipes in place of cats? any thoughts? It's either that or cut out the factory cats and make test pies, lol. Would the ecu flip out? I know some talanted welders. What kind of gain do you think I would get on a stock z doing this setup leaving the stock headers. Would it be worth it to change stock headers? What kind of weight do you drop loosing that stock y pipe and that heavy as a coffin mid pipe thing?
Anyone looking to do an install should check out the June 04 Super street they ahve a nice write up about it and has pictures with step by step instructions.
Old May 23, 2004 | 05:57 PM
Jason@Performance
Performance Nissan
yes the stock Y-Pipe isthe worst part of the stock exhaust system... replacing it witha Fujitsubo / JIC or other Y-PIpe will be almost the same as putting on a full cat back exhaust...
although.. the stock muffler weights a TON! So if you want to get the most out of your stock exhaust system... get rid of the stock Y-Pipe and switch out the muffler to a Greddy SP2 (only muffler replacement availble) and cut out the resonaotor in the mid pipe andreplace it with a straight pipe...
but if you want to do that... i would say just get the apexi world sport exhaust that comes with a mid-pipe and a fujitsubo or jic y-pipe...
The Stillen Cat Back exhaust is a good system... it is full cat back using an X-Pipe... You can use either the Stillen Test Pipes or one of the other test pipesavaible for this car... but... if you live some where where they have emissions test's go with a set of RT High Flow Cats... they flow closest to test pipes while keeping CARB exempt...
My car with only exhaust dynoed at 240... when I added high flow cats it dynoed at 249...
heavy coffin mid pipe thing? that is only in the G35 Sedan... the G35 Coupe mid pipe / 350z mid pipe is not very heavy at all... but the resonator on it is restrictive...
Old May 23, 2004 | 06:14 PM
PhoenixINX's Avatar
PhoenixINX
Jason - I'm going to have to call you out here.
On turbo cars, running MORE boost... and being even MORE prone to avoiding back pressure only made 20 hp going to test pipes.
You WILL NOT gain 50 hp from cats. Geeez dude, seriously.
Old May 23, 2004 | 06:33 PM
Jason@Performance
Performance Nissan
Was I talking about a turbo car?
Last I checked a Procharger IS and SUPERCHARGER...
Hi Dyno with Procharger only made 330
His Dyno with ProCharger / Borla headers / Borla Exhaust made 328...
TYno with Procharger / Borla Headers / Borla Exhaust / RT Cats / Tuning made 37X
Ill see if I can scan his dyno sheets or if he sees this thread Im sure he will post...
Old May 23, 2004 | 06:41 PM
  #38
PhoenixINX's Avatar
PhoenixINX
Superchargers react entirely differently than turbos do on exhaust systems, exhaust pulses, etc... each have different needs, and react VERY differently to systems.
Your comment on the other hand made it seem...
Supercharged stock Z + RT Cats = 50 hp.
Clarification Jason!!!!!
Old May 23, 2004 | 06:46 PM
  #39
Jason@Performance
Performance Nissan
appypollylogies...
i guess this wasnt saying procharger...
"we put RT High Flow Cats onto a car making 330 to the wheels with a procharger... after the cats were installed... over 380"
Old May 23, 2004 | 06:52 PM
  #40
zzzya's Avatar
zzzya
When you add in the tuning it makes sense. Tuning the FI cars is what really makes the HP. I'm sure adding the cats made a difference, but I would bet the main reason for the jump in HP was the tuning.
