Stillen Race Pipes..help
Old May 26, 2004 | 04:02 PM
FarSeide's Avatar
FarSeide
Default Stillen Race Pipes..help
Any tips on how to install this damn thing. Spent couple of hours trying to install but was not successful. I unscrewed 2 bolts from the header side, 2 from the Y Pipe side and 4 from the support frame but wouldnt come off. I yanked every which way but it wouldnt come off.
I was able to screw off one end of the bolt but the long bolt wont budge.
Anyone have any suggestions ?
Thanks
Old May 26, 2004 | 04:06 PM
stx's Avatar
stx
There is three nuts to remove on the header side. Then it should come off.
Old May 26, 2004 | 04:07 PM
FarSeide's Avatar
FarSeide
there is only 2 from the header side. I was not able to find the third bolt.
Old May 27, 2004 | 05:14 AM
stx's Avatar
stx
There is three nuts. They are shaped in a triangle. You can get two of the nuts from the bottom and the last you have to get from the top with extensions. I had to remove the air intake to get the driver side.
Old May 27, 2004 | 10:54 AM
jesfuego's Avatar
jesfuego
I just did the test pipes this past weekend, there are 3 bolts from the header side and 2 at the other end of the cats. you are probley going to have to buy some bolts, if yours didnt come with them. I put all new bolts on mine.
Old May 27, 2004 | 03:49 PM
FarSeide's Avatar
FarSeide
I checked out the car again and I do see that there are 3 from the header side and 2 from the y pipe side. Did the pipe just come off easy for you ? Did it come off when you unscrew the nut or did you had to yank the bolt out as well ?
apex locator
Jul 23, 2021 02:27 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
