Headers / Heat
Old Jun 14, 2004 | 07:52 AM
RCKTDAWG's Avatar
RCKTDAWG
Default Headers / Heat
The stock exhaust manifolds have heat shields. Has there been any problems with excessive heat after installing headers? Does the cabin get warmer or does wiring or plastic take a beating? Also, has anyone wrapped the headers or installed any sort or heat barrier?
Old Jun 14, 2004 | 09:03 AM
TheBigShow's Avatar
TheBigShow
i've heard ceramic coated headers will give off less heat than stainless steel ones. i guess that's something.
Old Jun 14, 2004 | 09:07 AM
FritzMan's Avatar
FritzMan
IMO, coating is always a good plan. It's really quite affordable for the benefits it offers.
I plan to ceramic coat both my Y pipe and my stainless headers once it arrives.
Old Jun 14, 2004 | 09:23 AM
Eagle1's Avatar
Eagle1
I have run 10,000 miles on my stainless headers, including four track events with them, no wrap or shield, and no problem in the bay or the cabin with heat issues etc., and I am running FI as well.
Old Jun 14, 2004 | 10:29 AM
stx's Avatar
stx
Default Re: Headers / Heat
My headers were giving off so much heat they were causing my brakes to fade. I had to wrap them with a heat shield to keep them from heating up my brake lines.
Old Jun 14, 2004 | 10:41 AM
alininger2001's Avatar
alininger2001
I would reccommend heat shieling the brake lines and the fuel and ac lines that are close to the headers.
alininger2001
I would reccommend heat shielding the brake lines and the fuel and ac lines that are close to the headers.
Old Jun 14, 2004 | 10:42 AM
12SecZ's Avatar
12SecZ
Ditto
Borla.
I have SS Brake lines and slotted and drilled rotors so I couldn't tell you about brake fade though.
Old Jun 14, 2004 | 11:16 AM
350ZRB's Avatar
350ZRB
Default ceramic coating
I bought DC Sports Header Ceramic Coated $260. And I just send them out to have Air Born Coating (similar to Jet-Hot) for $160.
Will have them back in about 2 weeks.
Old Jun 14, 2004 | 01:59 PM
alininger2001
You can buy a heat shielding tape, it works pretty good, just wrap the lines and there you go.
Old Jun 14, 2004 | 02:21 PM
RCKTDAWG's Avatar
RCKTDAWG
Thanks I will wrap the lines. I assume you can get the tape at OSH or Pep Boys or do you have to order.
EnjukuRacing
Sep 30, 2015 06:55 AM
EnjukuRacing
Sep 9, 2015 06:42 AM
