Injen SES Straight Tip Exhaust Stinks
Old Jul 27, 2004 | 04:42 PM
mgtibbetts's Avatar
mgtibbetts
Default Injen SES Straight Tip Exhaust Stinks
Just installed my Injen exhaust yesterday. Man does that thing smoke when you first start it up after installation. Now the inside of my car smells like an engine bonfire. Other than that it sounds pretty bad ***. Especially around 2500rpm. After installing the intake and Kinetix previously, I really couldn't hear my stock exhaust anymore but now I have that nice low rumble in the low range until the noise of the intake and plenum take over around 3500rpm. Car seems like it has more torque overall too. The only thing I noticed is that the driver side exhaust tip sticks out about 1/2 inch more than other one. I don't know how I can adjust for this. Maybe some of the welds were thicker on that side making the whole setup longer. Anyone else have a burnt smelling exhaust at first. Can't believe no one else mentioned it. My friend's fart can on his acura never smelled like that, but it was custom done.
Old Jul 27, 2004 | 05:04 PM
jlimquest's Avatar
jlimquest
Brand new Injen exhaust has oil coating inside. It will eventually burn out & will be fine...enjoy!!!
Old Jul 27, 2004 | 09:37 PM
CC 350Z's Avatar
CC 350Z
Exactly... Mine was fine after a day, no smell no smoke.
Old Jul 27, 2004 | 10:18 PM
ares's Avatar
ares
Veteran
might try just readjusting the pipes if ones different. loosen the bolts, adjust and retighten.
Old Jul 28, 2004 | 05:05 AM
350zSpeedRacer's Avatar
350zSpeedRacer
I second ares' idea. The exhaust has room for "play" on where you want your tips to be set at. I spent about 30 minutes trying to make sure mine were perfectly centered.
Old Jul 28, 2004 | 05:25 AM
OldManZ350's Avatar
OldManZ350
The first run of of this Exhaust had a design flaw. The pass side is about 1/2 in shorter. Injen replaced both rear mufflers section for me with second run parts and they are both the same now.
It was not the way you installed it.
Timrod
Old Jul 28, 2004 | 08:53 AM
D@ActiveTuning's Avatar
D@ActiveTuning
^^^ Did you have to ship your old ones back? Could you tell it was 1/2 in. shorter?
Old Jul 28, 2004 | 10:08 AM
BluZee's Avatar
BluZee
My exhaust is from the first run and everything fit perfectly and both sides are the same length. Mine stopped smoking the same day.
Old Jul 28, 2004 | 03:12 PM
OldManZ350's Avatar
OldManZ350
I have both the old and the newer version, and put them side by side, and there is clearly a design change on the passanger side rear muffler. Its is about 1/2 in longer then the old one. I'm a Mechanical Design Engineer.
Former B&M Designer, and have been in the Automotive Biz for over 30 Years-So Take MY WORD for it. IT WAS FIXED
And no they shipped me new ones and will be sending the old ones back soon.
TimRod
sales@czp
Sep 23, 2019 03:30 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
nanotech
Oct 2, 2015 05:02 AM
