confirmed that these are amuse.. to be sold in april of next year.. they achieved 306ps on their NA car (it would appear to be inconjunction with other NA mods)
Originally posted by ether seems like they did a comparison versus a test pipes and stock manifold setup and this came out about 9ps higher..
If the CAT is placed that far from the exhaust prot, the Catalyst will not be hot enough to work effectively. Hence the reason OEM uses twin CATs placed as close as possible to the exhuast mani.
Also done to reduice CAT light up time from cold start.
So , if you're rendering the CAT partially ineffective (most likely in violation of local emission laws) , one might ask why not delete the CAT altogether. Just a thought. Side note : it def would vilate CARB law in Cali. If you don't like the CAT delete RASP noise , use a resonator.
