any new news on the kinetix v.4 plenum ?
Old Aug 20, 2004 | 06:06 AM
MASTERPLAU's Avatar
MASTERPLAU
Question any new news on the kinetix v.4 plenum ?
its been a month or so since ive seen any posts regarding the kenetix v.4 plenum... seems like people arent having as many issues with the previous versions..... so here's my questions, how many miles have you driven with the v.4 and do you think this one is the real deal... or should i wait for the other plenums as discussed by other members of the forums...
thanks
Old Aug 20, 2004 | 08:43 AM
zachcrosen's Avatar
zachcrosen
Default Re: any new news on the kinetix v.4 plenum ?
thanks
I have had my V4 on for about 2 months and put on about 3500 miles. I have run 6 runs at the drag strip as well as 3 AutoX events. Each autox event had 5 runs so thats 15 autox runs in all. I have also hit my rev limiter several times and run well over 120 mph several times. With all of this, I have not seen any evidence of a crack or other problem with mine. There have been some documented imperfections in the molding process, but these have not caused any problems. It is beginning to look like the V4 just might be the real deal!! I know there are several Vortech systems that are running this plenum and I havent heard any problems out of theirs either.
Zach
Old Aug 20, 2004 | 08:50 AM
SungNamZ's Avatar
SungNamZ
My V4 is doing extremely well! I am one of those with a Vortech SC. TS did the "L" Flash. Max POWER = 324 Max TORQUE = 308.
Old Aug 20, 2004 | 09:49 AM
lsdunique's Avatar
lsdunique
no news........ is good news
We have had a couple small production flaws, but they are just that, small production flaws.
Old Aug 20, 2004 | 10:20 AM
dduck44's Avatar
dduck44
Go with it, it's got the best cross-section of looks, power and price.
Old Aug 20, 2004 | 06:54 PM
jor8888's Avatar
jor8888
I got 1 high spot rubbing the hood but only taking out paint on the hood , the plenum is fine.
Old Aug 20, 2004 | 08:04 PM
jun14scr's Avatar
jun14scr
lsdunique-- so.. you find my plenum yet?
Old Aug 21, 2004 | 09:34 AM
maserom's Avatar
maserom
I'm installing my V4 today!! First plenum ever. Wish me luck. Any advice is hugely appreciated.
Old Aug 21, 2004 | 10:26 AM
John@Victory's Avatar
John@Victory
bout 8000 miles now and no problems execpt the thing is rubbong on the strut tower bar and hood
Old Aug 21, 2004 | 12:43 PM
Static's Avatar
Static
Probably around 2K miles on mine.. no problems so far!! Working great!
Old Aug 21, 2004 | 01:46 PM
maserom's Avatar
maserom
Just installed the v4 for the first time ever. I made sure to not overtighten the 12 bolts. Just started the engine for 30 seconds to make sure no leaks. Everything appears to be ok. There was a little smoke from the drivers side, could that have come from the fuel line that runs to the throtle body, i disconnected the hose below the spark plugs. The smoke scared me a little. Also, it sure sounds different, you really can hear the air rumbling in the plenum, is this normal?? Quite a bit louder than the stock plenum.
Just checking.
Old Aug 21, 2004 | 01:58 PM
lowrider's Avatar
lowrider
Well
Look like fourth time was the charm
Lou
Old Aug 21, 2004 | 04:27 PM
ZIABLO's Avatar
ZIABLO
I am Batman
30 runs at the track on ONE day 3-4 weeks ago...no problems.
(1) 4 hour trip today, no problems.
I'm feeling pretty good about it.
Old Aug 24, 2004 | 07:53 AM
arodbrs's Avatar
arodbrs
jst got my new plenum, help w/ install process would appreciate it
when u get a chance?
Old Aug 24, 2004 | 08:14 AM
jlimquest's Avatar
jlimquest
I had mine installed by StreetImage (Baldwin Park) due to the delicate nature of the plenum. You can call Eric at 626-962-1503.
Old Aug 24, 2004 | 08:16 AM
maserom's Avatar
maserom
It is real simple, take your time, don't use any gasket akheasive. Make sure not to over tighten the bolts, go buy a torque wrench for $35 and tourque the plenum bolts to 8ft lbs.
Anyone having a problem with the electric fan coming on more frequently with the new plenum??????????????
Old Aug 24, 2004 | 09:18 AM
murrman100's Avatar
murrman100
How much did they charge you?
Old Aug 24, 2004 | 10:09 AM
jlimquest's Avatar
jlimquest
I had a plenum, cats & a UR pulley set installed for $250. Call Eric, they are very reasonable & know what they are doing.
Old Aug 24, 2004 | 10:58 AM
Hazade's Avatar
Hazade
I just saw another post about someone with this problem of extra heat after a plenum install. not sure if its related to the plenum or not or what kind he installed tho
