kinetix h/f cats dyno results...not good.
Old Sep 2, 2004 | 07:21 PM
Z BOY's Avatar
Z BOY
Originally posted by MIAPLAYA
No one at the dyno day had any ECU tuning whatsoever. Although the gas vould be a factor I doubt it. Matt did you put more gas in your car between dynos?
Prior to each of the two trips to Autotech dyno, i filled up with Arco (don't laugh!) 91 octane at same gas station by my house and then drove directly to dyno.
Old Sep 2, 2004 | 08:31 PM
Z BOY's Avatar
Z BOY
Originally posted by zxsaint
Lets see the charts...
Also, how soon did you redyno? While I don't have any evidence to back this up, I'm pretty certain the Z likes to pull timing when theres a sudden change in A/F. Takes some miles (maybe 100?) and some on/off cycles for it to settle. I noticed this every time I made a change on either side (intake/exhaust).
I'll find a way to upload the charts. I did my first 4 pulls on Sat, 8/28 with the kinetix cats, and then re-dyno'd 3 days later, 8/31, like 5 minutes after i had my stock cats reinstalled. What does it mean "to pull timing"?
Old Sep 2, 2004 | 08:44 PM
Z BOY's Avatar
Z BOY
Originally posted by 287HP
Since your A/F is around 13.1 with the stock cats(which is quite high already), you could be losing power because the cats are making you run too lean. If you get your A/F to the low 13s with the high flows, you will probably see more power! A Low 13 A/F ratio is where our cars make the best power. So you are already at that A/F with the stock cats, and that might be why you are making more power with the stock ones!
13.1 is high? That's not what i get from other posts re a/f.
Old Sep 2, 2004 | 08:47 PM
Z BOY's Avatar
Z BOY
Originally posted by lsdunique
I imagine it is possible that the internals of the converter have possibly collapsed.
It has never happened with our cats before, but I know it was a problem with the RT cats.
Give me an email at jamisonl@msn.com with original order info and I can have a new set sent out. I can send you a new set with a return shipping label for the old ones so you wont have any down time.
Would a collapsed cat result in a lean condition?
Old Sep 3, 2004 | 06:07 AM
jjellyneck's Avatar
jjellyneck
It would seem that you and many of the other guys would have been running leaner than Matt--you have more airflow mods.
Old Sep 3, 2004 | 06:14 AM
jjellyneck's Avatar
jjellyneck
The ECU senses that the engine might be running too lean and it retards the timing slightly. This will reduce your power output. After awhile (100 miles or so) it adapts to the new airflow as best it can (within its parameters of adjustment) and adds more fuel and also adjusts back to a more advanced timing. Power then increases. Other guys might be able to explain it better, but those are the basics, I believe.
Old Sep 3, 2004 | 06:23 AM
MIAPLAYA's Avatar
MIAPLAYA
Yeah Steel Heals had Plenum, DC headers, HF cats (Kinetix), Borla Trued Dual and POP Charger and did not have as high an A/F ratio as Z Boy
Old Sep 3, 2004 | 06:27 AM
jjellyneck's Avatar
jjellyneck
Are you guys posting your dyno charts someplace? That would be excellent.
Old Sep 3, 2004 | 06:34 AM
MIAPLAYA's Avatar
MIAPLAYA
I have mine...
Old Sep 4, 2004 | 02:42 AM
Z BOY's Avatar
Z BOY
The thing is, i had the kinetix cats on since June, plenty of time to adjust.
Old Sep 4, 2004 | 02:51 AM
Z BOY's Avatar
Z BOY
Since Isdunique is offering, I'm gonna exhange my questionable cats for a pair of new ones. Anyone want to buy 'em off me? I'm really liking the quieter exhaust note with the stock cats.
Old Sep 4, 2004 | 06:39 PM
Ryousuke's Avatar
Ryousuke
i thought that a stoicheometric a/f ratio was 14.7??
Old Sep 4, 2004 | 08:04 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
14.7 It is! I don't know where people are getting all these crazy numbers for Stoic.
Old Sep 4, 2004 | 08:07 PM
Hydrazine's Avatar
Hydrazine
14.7 It is! I don't know where people are getting all these crazy numbers for Stoic. rolleyes:
Old Sep 4, 2004 | 08:58 PM
Zmego1985's Avatar
Zmego1985
My z is running leaner with all my mods thats what im getting the reflash while im installing my JWT cams. When i dynoed my AF was a high 14 to low 14 all the way through.
Thanks Glen
Old Sep 5, 2004 | 04:45 PM
Hydrazine's Avatar
Hydrazine
14 all the way through is dangerous. Get that fixed fast.
Thanks Glen
Old Sep 10, 2004 | 05:46 AM
Z BOY's Avatar
Z BOY
Just rec'd my new cats today. Thanx, Kinetix, for your lightening-fast response! Now, anyone interested in some brand new h/f cats for $350 shipped? I've decided to stay stock plenum-back.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
