Helix Test Pipes
Old Dec 9, 2004 | 01:16 PM
raptorbh12's Avatar
raptorbh12
i have the same exact noise coming from my pipes, when decelerating it sounds almost similar to a blow off valve but last longer its midway around 2-3k rmps
Old Dec 10, 2004 | 02:07 PM
Nexusindustry's Avatar
Nexusindustry
Exhaust leak...check the seals and how they mate...what happens many times is that when factories weld on the flanges, they do them at an angle and the result is that the metal is heated up so much that the flange also stays at that angle and does not line up properly.
If you really want to be sure, when the car is really cold, throw some water on the joints/flanges to see if the water bubbles...if that is the case there is your leak
Victor D.
www.nexusindustry.com
Old Dec 12, 2004 | 02:14 PM
raptorbh12's Avatar
raptorbh12
exhaust leak my a$$ my entire exhaust actually fell off during a turn, i do not have an aftermarket exhaust the OEM exhaust the Nissan stock exhaust broke off my car as i was turning going to work. Its going to be replaced in 2 days when they get the part in. also btw exhaust leaks are loud but when ure car sounds like an indy car check for missing bolts and missing pipe sections.
Old Dec 12, 2004 | 08:15 PM
350G's Avatar
350G
Holy **** . . . that's . . . . uhhh . . . that sucks.
And to bring an end to this thread, I bought these test pipes in question through his ebay auction, so we'll see what's going on. BUT, I do have a TT, so it may change a few of the conditions
G
Old Dec 19, 2004 | 03:58 PM
Logikal_Disasta's Avatar
Logikal_Disasta
YE SCREW THAT I WANT A BOV SOUND WHEN I INSTALL MINE LOL
Old Dec 19, 2004 | 04:17 PM
ReavTek's Avatar
ReavTek
I have the same hissing sound you mention, but only when letting off the gas and using some engine breaking.
Edit: I have the Stillen Test Pipes, Fujitsubo Y-Pipe, and Tanabe Exhaust.
Old Dec 19, 2004 | 05:23 PM
raptorbh12's Avatar
raptorbh12
ok nissan bought me a new exhaust now after mine fell opff around that turn. but yea when i had my test pipes it was a hissing noise when i let off the gas and it only occured between 3 and 2k rpms. test pipes were a noticable increase in power for me though and im going to put them back on my car soon, i cant stand the stock noise or lack thereof.
Old Jan 19, 2005 | 04:00 PM
Import-Tooner's Avatar
Import-Tooner
What about using helix test pipes with stock exhaust? Shouldn't that muffle some of that raspyness but still give a bit more sound?
Old Jan 19, 2005 | 05:47 PM
raptorbh12's Avatar
raptorbh12
thats exactly what i have, the Helix test pipes on a stock exhaust. it makes it sound alot meaner and very unrefined. But personally i like it, it dosnt sound like a Honda or cheap mufflered car.
Old Jan 19, 2005 | 06:34 PM
FairladyZ's Avatar
FairladyZ
Originally posted by mchapman
Maybe they installed a twin turbo instead of test pipes.
Seriously though, I have the same as above (helix and stock exhuast) and love it. Oh and I still have the stock resonator as well.
Old Jan 20, 2005 | 10:34 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally posted by zoom350
Thanks Dave079... Wow, the smell is really strong.
You are smelling the raw exhaust since you no longer have a catalyst. You will also notice your exhaust tips turning brown and then eventually black unless you clean them all the time.
Old Feb 14, 2005 | 10:08 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved.
Old Feb 15, 2005 | 10:15 PM
time4aspliff's Avatar
time4aspliff
I've got non-resonated test pipes with a stock exhaust and I'm also getting the distinct hissing sound when I let off the gas. It doesn't bother me too much but if it's a leak then I'm worried that I might be losing some power.
I also get subtle hissing at low rpms in 6th gear (when I barely give it gas).
I tried applying exhaust sealant (that putty stuff) on all the test pipe flanges but I still get the hissing noise. I don't get it...
It seems as if the rasp is only present at partial throttle between 3,000-4,000 rpms. When I punch it, there's no rasp; it just sounds really pissed off!! I haven't decided if it's a good sound yet-we'll see...
Also, the other day I heard some dude punch his throttle in a 360 Modena on the freeway and it was the raspiest exhaust I've ever heard. Oh, and my co-worker just got a 2005 Boxster S and from 4,500-6,000 rpms it's raspier than my setup (but not louder). So we're not the only ones "buzzing" around out there...
Old Feb 15, 2005 | 11:05 PM
Z BOY's Avatar
Z BOY
i have posted about this before: like a little mini nitrous purge sound whenever i let off the gas ever since i installed my kinetix resonated test pipes, and a very smart member whose username i forget right now (chad) said it is normal with test pipes.
now that i know its normal, i love the sound.
Old Feb 15, 2005 | 11:28 PM
time4aspliff
Maybe I'll just start telling people that I'm running turbos with an external wastegate.
[just kidding]
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
