test pipe rasp solution
Old Nov 13, 2004 | 11:57 PM
dchi_t's Avatar
dchi_t
Default test pipe rasp solution
hey guys. today while changing my tranny fluid i notiiced our cats is kind of a double layer. basically its the cats w/ some kind of heat resistant foam and an outer layer of steel clamped tightly together. does the 2nd layer of foam and steel act as a vibration damper? cuz the rasp of test pipes comes from the thin tube used correct? what if we can duplicate the stock design and make our own damper of some kind and get rid of the rasp? thanks! just an idea
Old Nov 14, 2004 | 03:15 PM
myz8a4re's Avatar
myz8a4re
everyone has already or is eliminating thier rasp by installing inline resonators or buying resonated testpipes............best of luck!
-justin
Old Nov 14, 2004 | 06:11 PM
dchi_t's Avatar
dchi_t
what are inline resonators? sorry for the newb question, but i know what resonated test pipes are but are the inline resonators like an additional piece? thanks
Old Nov 14, 2004 | 11:34 PM
Poizon's Avatar
Poizon
Test pipes with resinators from La Bree motor sports 818-704-7950 The only test pipes with resinators that never give off raspiness. 375.00 delivered price used to be 450.00
Old Nov 15, 2004 | 07:24 AM
myz8a4re's Avatar
myz8a4re
Ill have to diagree with poizon, my kinetix testpipes do not let ANY rasp through........in no way am I saying la bree products aren't good, I'm just saying that as far as resonated testpipes, there are other qaulity products out there as well......
Inline resonators are just adding the resonators to your current unresonated testpipes. They then look identical to the resonated style. Most performance muffler shops carry these resonators. They can be purchased & added into your setup fairly cheap if you have already purchased the nonresonated pipes. If you have not yet purchased testpipes I suggest buying the resonated style to eliminate any further future hassle. If you have purchased some already & are experiencing the rasp then you can add resonators as I mentioned above......do a search on resonators & resonated testpipes. You'll run across the numerous threads, some with pictures, of what I'm describing.....best of luck
-justin
Uriyo_
Sep 8, 2021 08:46 AM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
