need help!
Old Nov 29, 2004 | 10:12 PM
chi-Z's Avatar
chi-Z
Default need help!
i took apart my dash to make sure my stereo wasw working right after i put everything back together nothing seems to work. my oil pressure and battery gauges work but everything else doesnt. my ac/ controls, speedometer, and all the vdc,slip, bat,abs, lights etc. are lighted up. i checked all the fuses and it seems to be fine. i was wondering if i should take it back to nissan. or is there an easy fix for it, would it be covered under warranty. please everybody give me your input
Old Dec 3, 2004 | 03:50 PM
LaidbackRacr's Avatar
LaidbackRacr
Default Re: need help!
I dont think you mucking around with wiring will be covered under warranty. I would check the wires carefully buy a test light and make sure everything that needs power is getting it, worse case scenario take to stereo installer they should be able to check it for you much cheaper.
-Chris
