Oil Filter - Which one do you use? Recommend?
Old Sep 29, 2004 | 11:50 AM
Nominee's Avatar
Nominee
Default Oil Filter - Which one do you use? Recommend?
Do you guys/gals use the 350Z oil filter or the Maxima oil filter?
350Z - 1520865F00
Maxima - 152089E000
The parts guy told me to use the Maxima filter as it is larger than the 350Z one.
Any thoughts??
Old Sep 29, 2004 | 04:52 PM
GATORZ's Avatar
GATORZ
Default FRAM DG7317
Old Sep 29, 2004 | 05:04 PM
n8vz's Avatar
n8vz
goto mynismo.com and look up oil filters. Both are suppose to fit. The older style filter looks larger, but i am not sure if it has more filter media.
Old Sep 29, 2004 | 09:58 PM
Nominee's Avatar
Nominee
Yes, I want the one with the better filtration rate. Usually, larger filters have better filtration....so...i don't know...
Old Sep 30, 2004 | 12:24 PM
Jaki's Avatar
Jaki
I use the K&N Gold oil filter or the Mobil 1 (If I find it right away when needed) If you need the part # for either one, pm me and I'll look it up and pm you back.
Old Oct 3, 2004 | 10:30 AM
mberthia's Avatar
mberthia
Anybody have an opinion on the Purolator or Purolator Pure One filters ? They are readily available...
Old Oct 3, 2004 | 07:47 PM
Jung918's Avatar
Jung918
I get my Mobile 1 oil filters at Autozone.
Old Oct 4, 2004 | 09:54 AM
timmins's Avatar
timmins
Which Mobil 1... the 105, 108, or 110?
Old Oct 4, 2004 | 01:29 PM
Jaki's Avatar
Jaki
Mobil M1-105
Old Oct 4, 2004 | 03:49 PM
lowrider's Avatar
lowrider
K&N, Model HP-1006. Great Filter with a welded on nut for easy filter removal.
Lou
Old Oct 12, 2004 | 04:11 PM
HokieZ's Avatar
HokieZ
I use the M1-105 as well (it's a BIG filter, but fits perfectly. I actually have a bunch of them that I can send for less than what you'd pay in the store. If you're interested PM me.
Old Oct 13, 2004 | 03:55 PM
fueledbymetal's Avatar
fueledbymetal
That's all I use on my cars. Great design (unlike el cheapo filters like fram) and good price! They're also the preferred brand for subaru enthusiests
Old Oct 24, 2004 | 06:15 PM
Losing Grip II's Avatar
Losing Grip II
same here.
john
Old Oct 25, 2004 | 06:28 PM
johnsZ's Avatar
johnsZ
I use the K&N, and the K&N air filter as well (I think it is the 2032, but check the K&N web site)
You can get them at Checker, Autozone, and speed shops
Sound is a bit deeper with the K&N
Old Oct 26, 2004 | 04:33 AM
Asterix's Avatar
Asterix
Surf the web some and you'll find that the Purolators are among the best. Frams are crap. They used to be good, but aren't any more. If you don't believe anyone, do your own test. Buy some filters and use a hacksaw or can opener to open them up (carefully) then compare the size of the filtering medium and construction.
I'll recommend the Purolator.
Asterix
Old Oct 26, 2004 | 04:55 AM
lgangi's Avatar
lgangi
Originally posted by Losing Grip II
same here.
john
Which Purolator Oil filter do you use... is it the 14610 or have you found a larger version?
Old Oct 26, 2004 | 07:59 PM
Losing Grip II
i found a larger size. i have to check the number for you. when compared it to a Car Quest oil filter, it was about an inch longer and looks heavier duty. also not to mention it has a nice rough flat blue paint apllied to it to get it on there easier.
john
Old Nov 29, 2004 | 05:06 PM
CESAROTORRES's Avatar
CESAROTORRES
Do you still have filter available? Price? ship to 32822 Orlando FL
Cesar
2004 Roadster
Old Dec 4, 2004 | 03:22 AM
bwilliams's Avatar
bwilliams
When you are discussing oil filters and deciding which one to use, don't be mislead that you could properly judge a filter by cutting it open...waste of time. For an automotive application, you're concerned about three things: 1) particle size permanently removed, 2) pressure drop , 3) particle holding capacity, in that order.
Fortunately, there is ample independent (usually unbias) research that may lead you to the same conclusion I reached:
Use Mobil 1 or K&N filters. Don't take my word...you don't know me...I can't even spele...do your on research on the filter properties that matter. An extra couple bucks for these filters is a bargain.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
