Rear bumper squeaking loudly!
Old Jan 8, 2005 | 08:16 AM
Dissolved's Avatar
Dissolved
Default Rear bumper squeaking loudly!
After 6 months of squeaking, I've isolated the noise to the rear bumper of my car. If you push on the rear bumper, it squeaks loud. Does anyone know of a quick/easy fix for this? Should I remove the rear bumper? I'm positive this is where the noise is coming from
thanks!
Old Jan 9, 2005 | 06:58 AM
Netko350Z's Avatar
Netko350Z
Default Re: Rear bumper squeaking loudly!
thanks!
My rear bumper squeeks on both sides right behind the wheels
It is like there is a missing support piece. Is this your same problem?
Old Jan 9, 2005 | 09:11 AM
Dissolved's Avatar
Dissolved
yes, EXACTLY! the location
Old Jan 18, 2005 | 07:54 AM
Netko350Z's Avatar
Netko350Z
Anyone else have this problem?
Old Jan 18, 2005 | 08:43 AM
Dissolved's Avatar
Dissolved
Found the problem when I was installing my exhaust. A bracket was rubbing against the bumper. Dont know how that happened. I bent it back with a long screwdriver, problem fixed..
Old Jan 18, 2005 | 05:04 PM
Netko350Z's Avatar
Netko350Z
Acutally I was feeling up into the wheel well and I felt a hole where the two pieces of the bumper should match up. It is toward the middle right where the rear splash guard is located.
A buddy of mine owns a collision center and he said he has the perfect thing to fix it.
I will check for a bracket as well.
Old Jan 18, 2005 | 05:15 PM
Dissolved's Avatar
Dissolved
has to be it. If you get underneath the car and look, you will see it
Old Jan 19, 2005 | 06:01 AM
Netko350Z's Avatar
Netko350Z
Ok as soon as the temp is above freezing I will crawl under and take a look. Actually my Z is in hibernation right now in my garage.
6 weeks to go!!!
Old Feb 14, 2005 | 11:25 PM
TtOrMaMnY's Avatar
TtOrMaMnY
yes i ahve the exact same problem!!
Old Feb 15, 2005 | 01:41 PM
Netko350Z's Avatar
Netko350Z
Feel for the holes on the bottom edge. If you move them they will line up and provide support for that section of the bumper.
Old Mar 16, 2005 | 08:17 AM
BOOFER7's Avatar
BOOFER7
I too have this problem occasionally. Any pics of this particular hole bracket??
Justin100
Nov 25, 2021 06:26 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
