Synthetic, Hard on Syncros?
Old Feb 19, 2005 | 06:32 PM
ZaggieZ's Avatar
ZaggieZ
Default Synthetic, Hard on Syncros?
I have heard that switching my 6MT fluid to AMSOIL 75w-90 is extremely hard on the syncros(what are syncros and what do they do). I am planning on changing the Motor Oil to AMSOIL 5w-30, and both the 6MT and Diff to AMSOIL as well. Will switching the MT fluid hurt the syncros?
Old Feb 19, 2005 | 09:36 PM
n8vz's Avatar
n8vz
6MT gear box calls for GL-4 fluids.. do not use GL-5 as the extra extreme wear additive will corrode the yellow metals. Stick with GL-4 for the transmission. GL-5 is fine for rear differential
Old Feb 21, 2005 | 07:47 PM
ssk0771's Avatar
ssk0771
If you want to use synth tranny oil, use Redline MTL 70-80w. Even though its synth oil, its GL4.
Old Feb 22, 2005 | 08:47 AM
Z'd's Avatar
Z'd
I switched to Amsoil Series 2000 75W-90 at around 3000 miles to improve shifting ease. I am extremely pleased with the results and the fact that I could use one oil in the 6MT and rear diff, rather than mixing, as Redline users have.
Although the API specs matched Nissan's requirements, I called Amsoil's techs, who reviewed the requirements and agreed that it was an excellent choice.
Amsoil has changed their gear lube offerings since and no longer offers a lube that meets the GL-4 rating for anything but rear diff use. Unless you could locate some of the older Series 2000 lube, it appears like a different brand will have to be used in the 6MT.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Stevo Z
Oct 3, 2015 09:14 PM
