Anyone else's front tires scalloped? Please respond if you have 4500+ miles.
Old Nov 23, 2002 | 03:31 PM
droideka's Avatar
droideka
Default Re: Pic of situation Droidekaus is talking about
Originally posted by ChinaClipper
See attached photo below. This is of my car with 4800 miles. What droidekaus is referring to is a "beveling" of the inboard tread blocks. Note in the picture, the way the dirt from the ground marks the block in a triangular pattern rather than a rectangular pattern (as it should) on the outboard tire tread blocks. This was discussed at the Dallas Z meet organized by TXSTYLE today, and every 350Z with 4K+ miles on the OEM Bridgestones exhibited this kind of tire wear. In person, you can better appreciate this condition by running your fingers along the inner tread blocks fore-to-aft and feel the uneven wear. It is also noticeable that the inboard tread is wearing faster than the outboard tread. droid is led to believe that possibly Nissan has a camber problem with our cars. More to come with more mileage.
Thanks, Mike! Would you cross-post this pic to my new thread?
Old Nov 23, 2002 | 05:52 PM
bastard's Avatar
bastard
Default caster
Originally posted by cotmfk
What exactly does the caster adjustment do?
Caster is the front-to-rear positioning of the wheel. Like if the driver side wheel is further back than the passenger side, the car will kind of fade off to the left because there is slightly more weight on it due to the increased amount of car in front of the wheel.
It still seems odd to me that Nissan supposedly doesn't have camber adjustments, especially with so many people lowering cars and destroying their tires by doing so.
Old Nov 24, 2002 | 05:00 AM
cotmfk's Avatar
cotmfk
Thanks for the explanation. Yeah, I think Nissan MUST have camber adjustment. I don't see how they couldn't. Every car has it, right?
Old Nov 24, 2002 | 05:15 AM
MustGoFastR's Avatar
MustGoFastR
No, that's why they make camber kits.
Old Nov 24, 2002 | 06:02 AM
's Avatar
Newbie
Go to a tire store like Discount tires and ask them what normally causes this to occur. One I know for sure is the Rotation of the tires. At 5100 miles you shouldn't have seen that happen (IMO). The other reason slips my mind yet I was told them both a few months ago when I bought new tires on a Saturn.
Old Nov 24, 2002 | 06:22 AM
Boomer's Avatar
Boomer
Originally posted by djtonium
I'm not fond of the tires either.
Treadwear of 180??????!?!?!?
My dad's got ZR tires on his Z32 with
treadware of 300, and they grip
the road very well.
He just bought a pair of BFGoodrich
GForce tires from www.tires.com
for under $120 each.
According to Tire Rack specs, the OE RE040s have a tread life ratio of 140! Owners of other cars have reported even shorter treadlife, like 7500 miles and worn out on one side.
Old Nov 25, 2002 | 01:05 PM
Deb's Avatar
Deb
Default Tire Wear
On behalf of my wife (she's Deb), I talked to the service people at the dealership in Tulsa, OK who will be delivering her car. All the service mgr could tell me was that he was aligning every 350Z that came in because he felt that kind of car should be aligned before hitting the street. He said that none had come back so far but that they hadn't sent that many out that would probably have over 4000 miles yet.
I am new to this argument or debate - does anyone have a definitive answer as to what is causing this premature wear? I've read some posts saying that it's alignment, others that it's the tires, some are blaming it on no camber adjustment ....
My wife has a 300ZX 2+2 that will eat tires if it's driven hard. I think the most she has ever managed to squeeze out of a set of tires was 18,000 miles. The Michelin Pilot's have been the best tires so far. She has 113,000 miles on her 300. I have had it aligned and have had different shops tell me different stories. Some insist on weighting the car on both driver and passenger side, others say no, while some say there are two ways to set up the car ("in town" and "highway - led sled" driving) and setting it up one way and driving the other will eat tires and cause uneven wear. I doubt that she will ever see a set of tires that will go even close to the 40,000 I get on my truck. I'm looking at a G35C for me - here's hoping it doesn't have that problem.
If you do have a definitive answer, I would appreciate it.
Old Nov 25, 2002 | 01:20 PM
Thunderbolt's Avatar
Thunderbolt
Charter Member #88
Originally posted by raceboy
Scalloping/Cupping
Probable Causes
- worn bearings, shocks, springs or other suspension compnents
too much camber will produce the same symptoms as weak or sagging springs. this can produce a wear pattern as discribed above. other suspension compnents is what that means. camber has to be adjustable to compensate for every day wear of the suspension componets.
Nissans quality is good but not that good.
Old Nov 26, 2002 | 02:51 AM
Thunderbolt
Charter Member #88
Caster is the amount the upper ball joint tilts rearward in relationship to the lower ball joint. The more rearward tilt the more the tire will try to steer straight. To compensate for road crown the left upper ball joint is usually moved ½ degree farther forward than the upper right ball joint. This will cause the car to pull slightly to the left. Caster does not cause tire wear. As to the tire wearing on the inside edges that is a camber issue and from my driving experiences this car has a lot of negative camber. That is why it turns so well. Add about one degree of camber to both sides and that tire wear will go away but so will the handling.
BTW go look at other cars tires and you will see cupping is very common.
Old Nov 26, 2002 | 06:16 AM
jelledge's Avatar
jelledge
Default No abnormal wear on mine 4000miles
I've got a touring 6spd with 4000miles and not seeing any kind of abnormal wear on front ro rears. I run 35psi cold tire inflation pressure and when driving around it general hangs around 36-38psi.
If your tires are really getting feathered or scalloped that bad then something is wrong or you got some bad tires.
Also, I have seen where this scalloping can be caused by a poorly balanced tire. What happens is that the tire hops ever so slightly when rolling. This is caused by a tire that has an improper road force distribution.
I have a '91 BMW 325i that had a serious tire scallopping problem. After getting numerous alignments and tire balancing and even a new set of tires I still had the problem. Finally I found out about the Hunter GSP7200 roadforce tire testing machine. The system applies a road force to the tires when spinning. This quickly identified that one of my tires was slightly out of roud. The system then matches up the high spot on the tire to the low spot on the rim. Guess what -- worked great problem solved.
However. many - many cars on the market today wear tires unevenly due to their suspension setup. I have a Mazda RX7 that loves to eat the inside edges of tires both front and rear. Guess what it's normal.
Old Dec 3, 2002 | 02:08 PM
Vincey2kr1's Avatar
Vincey2kr1
5k miles just checked and my tires are doing the same, cupping on inside.. Been running a pressure of around 35psi cold all way around. This is a performance model with 18"wheels.. Anyone dealt with NIssan yet on the issue?>
Old Dec 3, 2002 | 03:23 PM
MELRUMMY's Avatar
MELRUMMY
Default Tires at 6000 miles
I just had my car serviced at 6000 miles and so far no problem with the tires. Perhaps some of us are driving too aggressively.
Keep on Z' Still Jumpin' for Joy !!
Old Dec 5, 2002 | 10:34 AM
cotmfk's Avatar
cotmfk
8000 miles is a bit steep! What kind of tires are your car again? I can't believe that they would equip the car with such low wearing tires.
What you can do, though, is go and look at different tires possibilities, to see if there is something out there that will wear less...
Old Dec 5, 2002 | 10:39 AM
MustGoFastR
The stock RE040s are very soft compound tires. The S-03s have a much higher treadwear rating (in addition to being rated much higher in every other category), I'll be switching to them as I wear out the REs.
Old Dec 5, 2002 | 11:13 AM
LA-Z's Avatar
LA-Z
Hmmm. 5000 Miles. No Scallops. Scept when I order them. No Road noise. No Blose problems cause I didn't get the Blose System. Just to let you guys know, check out some Stook Boards, they are constantly replacing rear tires because of constant wear. One thing I don't understand is this: "I shouldn't have to replace the tires all the time I mean it's not like this car is a Ferrari/ Porsche" argument. Why? Do Ferrari's/Porsches use inferior tires? What causes the need for constant tire replacement on their cars. Could it be that the cars are driven at exsessive speeds/handeling and have a lot of horsepower sent to the wheels? Couldn't the Z fit this catagory? What about an FI Z33 with 400+RWHP? Would it be accceptable then?
Old Dec 5, 2002 | 12:52 PM
  #38
ChicagoEZ's Avatar
ChicagoEZ
Default Dealerships Response the issue
I took my Z in due to the loud rumbling between 15-30 mph, i had no idea what the prob was, the tech took it out and said my tires are feathered, Long story Short they are replacing the fronts for free and giving me a free alignment. For all you guys who think feathering is normal then get your head checked, cuz no car should sound the way mine did at 7000 mi, just take it to the dealer, i predict that this is going to be a major problem very soon involving alot of Zs
Old Dec 6, 2002 | 11:37 AM
  #40
cotmfk's Avatar
cotmfk
The Kuhmo Ecsta Supra is a Z rated tire witha tread wear rating of 40,ooo miles. It doesn't have super excellent grip, but that is expected since the mileage is higher. It might be something for you to look into.
