Window problems!!! Anyone else had this happen
Old Mar 16, 2005 | 01:32 PM
sisco534's Avatar
sisco534
Unhappy Window problems!!! Anyone else had this happen
Last night I got home had the window cracked(I smoke) pulled into the driveway rolled the window up then it rolled down about 6 inches , so I pussed the button again it went up then rolled back down again . So i pulled it in the garage left it like that all night this morning it was allright???? Ha sthis happened to anyone else? Is there a TSB on this? Do I need to take it in for service? I have never seen anything like it!
Old Mar 17, 2005 | 01:59 AM
mikerz's Avatar
mikerz
That is a strange problem that you've encountered with you Z. Either it be TSB or not just have dealer fix the problem since still under warranty.
Old Mar 17, 2005 | 02:23 AM
southern_info's Avatar
southern_info
It happen to me. What I've done when that situation happens. I just hold up on the button to keep the window up and take the key out of the ingition. Then I'll take my finger off the rolling the window up button. The window will stay up and after that, the problem won't happen for a little while. Don't get me wrong it will happen again, but I have no idea what causes it and it only happens every blue moon. Hope that temp. fix will work for you.
Old Mar 17, 2005 | 05:18 AM
lovetoclown's Avatar
lovetoclown
I have the same problem. You need to have your power window motor replaced. Alot of people are running into this problem.
Old Mar 18, 2005 | 09:51 AM
t350z's Avatar
t350z
I was having this occur intermittently, then it became more frequent. With mine it only happened with the "auto up" feature. If I used the switch without engaging auro up it would work okay. I took the car to the dealer and they re-set the power window control module under warranty, it hasn't happened since. I think there may be a TSB on this, but I'm not sure. My dealer told me they are seeing this on Maximas too.
Old Mar 18, 2005 | 02:00 PM
sisco534's Avatar
sisco534
Angry Dealer is replacing Monday
They said this is common.........why.... but Monday they are putting new motor in the driverside door..anyone else with this problem this seems to be common better get it fixed under warranty while you can....this must be like the transmissions
Old Mar 18, 2005 | 04:17 PM
Ozz's Avatar
Ozz
I had the same problem. I took the car to the dealership and they fixed it under warranty. When I picked up the car the service rep told me my stereo installer must have hit the switch when the door panel was off. All they had to do was reset the switch. I told him the stereo had been done for a year before the window started dropping. Not sure about some of these guys. I think they are trained to always pass the responsibility on to the owner.
Old Mar 22, 2005 | 12:42 PM
KDsZ's Avatar
KDsZ
Default Service Bulletins
Here is a listing of the currently active Service Bulletins for the Zed.
http://www.nissanhelp.com/Bulletins/350Z/Year.htm
check the site, you may be experiencing some other problems that are warranty items.
Old Mar 22, 2005 | 01:05 PM
bixby's Avatar
bixby
Yep. I had mine repaired twice. Get it taken care of ASAP cause it will get much, much worse.
Old Mar 23, 2005 | 11:39 AM
silverstoneTT's Avatar
silverstoneTT
Don't smoke in the Z!
Old Mar 23, 2005 | 02:06 PM
silverstoneTT
Old Mar 24, 2005 | 12:42 PM
sisco534's Avatar
sisco534
Sorry about your wreck silerstoneTT
Old Mar 24, 2005 | 01:01 PM
jmagilto's Avatar
jmagilto
Default I pulled into PHL about 40min ahead of my departure time
Put down the window to get a ticket @ economy parking. Pushed it up - it went up and went back down and down it stayed. I was very frustratrated. I could not leave it open - but I also could not miss my flight. I decided to leave it and call my wife to come down and get it with my dad. Got back in to try one last time, turned the key and voila - it went up - without any help or push of any button.
I was more than a little miffed - Took it to the dealer when I got back and they fixed it - no problem under warranty (Colonial Nissan Rocks).
My point? - If its happened to you once - get it fixed. You never know what circumstance you may find yourself in where having a dead window in the down position may cost you.
Old Mar 24, 2005 | 01:17 PM
sisco534's Avatar
sisco534
Dealer fixed New power window motor , also monday for the fuel door fix they said they had to fix the fuel door , told them I can do it myself no they want to keep it all day to fix it. Oh well it will be fixed. Went to www.nissanhelp.com READ ALL THE TSB, printed so the dealer wouldnt give me slack.
Old Mar 24, 2005 | 02:11 PM
ANXIOUZ's Avatar
ANXIOUZ
I'm still hung up on the fact that you smoke in the Z.
Old Mar 29, 2005 | 07:04 PM
bstfugtfomrfn's Avatar
bstfugtfomrfn
+1
500 bucks land
..grumble..
bastards
~AJ
Old Mar 29, 2005 | 09:11 PM
hndumafia's Avatar
hndumafia
that happened to me. and soon after the window motor completely broke and the window would not move from the up position. replaced by dealer for free under warranty.
Old Apr 9, 2005 | 07:39 PM
Dre Dizzle's Avatar
Dre Dizzle
Window motor went out once 6 months ago-fixed, went out yesterday!!!! Gotta go right back to the dealer!
Old Apr 23, 2005 | 10:09 AM
dbpoet's Avatar
dbpoet
Took my 03 touring in last week because drivers side window wasn't going down when opening and closing door and it was lowering about 6" by itself. Dealer ordered a new regulator and installed it yesterday. Window seems to be working now but I still don't think it drops the 10mm its supposed to when opening and closing door. I think the dealer must have had some bad reviews of service dept. because when I was leaving he told me "you'll be getting a survey from Nissan, could you do us a favor?" I told him if the problem was fixed I would.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
