camber
Old Mar 24, 2005 | 04:02 PM
lilkrnthugboi's Avatar
lilkrnthugboi
Default camber
does anyone have a camber on there stock 350z? cuz mine is pretty bad and it isn't even modified
Old Mar 24, 2005 | 04:33 PM
christoc's Avatar
christoc
Pretty bad how?
Old Mar 24, 2005 | 09:01 PM
lilkrnthugboi
looks like it has a camber whenever u lower any car. i'll take pictures of it
Old Mar 26, 2005 | 06:05 AM
bosotheclown2002's Avatar
bosotheclown2002
You can adjust the rear camber back into a reasonable range quite easily but if it is the front you would have to get replacement front A-arms. I have seen quite a few 350Z's where the rear camber is quite excessive and if not corrected it will cause the inner edge of the rear tires to where out pre-maturely.
Old Mar 26, 2005 | 01:04 PM
lilkrnthugboi
i can adjust the rear without a camber kit? my fronts r fine, but the rear is kinda bad
Old Mar 27, 2005 | 06:41 AM
myz8a4re's Avatar
myz8a4re
yes, if you look under your z in the rear there is a camber rod that runs from the lower suspension bracket to the rear subframe. on the frame side there is a cambolt. if you turn the cambolt the rod will move forward or backward either pulling your camber in or pushing your camber out. very easy to adjust though i highly recommend an alignment shop do it to get the correct setting as camber adjustments affect your toe settings. throwing your toe out of spec will eat your tires up quikly......just to note, all z's have fairly agressive rear camber settings from the factory. the look is hieghtened with aftermarket(heavy offset) wheels or wheels spacers on the factory wheels as the camber angle becomes more noticeable...... the bottom of the wheel gets closer to the fender lip/well area allowing you to see more of the camber.........
-justin
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
