Need Part Number: Door Trim
Old Jun 8, 2005 | 04:20 AM
Vestas's Avatar
Vestas
Default Need Part Number: Door Trim
I'll try and post a picture later today. Friend of mine was getting out of the car and got his baggy pants/hip hooked on the outside top corner of the driver side door, it pulled the plastic coated metal door trim off.
The piece I'm referring runs along the top of the door, where the window rolls in. It's one long piece (runs from front of door by rear view mirror all the way to the back of the door), looks like plastic but has some metal for structure. Unfortunately it's bent pretty bad and there's only one screw holding it in on a very small piece of plastic (which cracked).
Anyways, I could use it's part number so I can order a new one. Easy enough to replace (pop off the interior door panel, roll the window down and should be able to mount on a new one). Could save me a painful trip to the dealer to get a part number. Driver side door mind you!
Old Jun 10, 2005 | 04:41 PM
raycs7's Avatar
raycs7
You did not specify a year.
The outer belt moulding LS coupe 2004 and 2005
80821-CD711
Older model is 80821-CD000 , more expensive
Hope it helps
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tochigi_236
Sep 27, 2015 03:40 PM
