Accelerator Pedal Position Sensor
Old Jul 5, 2005 | 11:36 AM
SDPADFN's Avatar
SDPADFN
Cool Accelerator Pedal Position Sensor
I was taking a small road trip, cruising down the freeway and all of a sudden, I lost all acceleration power. I took my Z into the shop and ran a diagnostic test and it came up with three (3) different codes:
Code 2122 - Accelerator Pedal Position Sensor
Code 2138 - Apps Range Problem
Code 1229 - Sensor Power Supply Circuit Short
Is this a common accurance on the 2003 350Z? Does anyone know if Nissan will cover the cost under the extended warranty? Any advise would be grateful!!
Thanks!
Old Aug 1, 2005 | 07:20 AM
theking's Avatar
theking
Same thing happened to me. What was the problem?
Thanks!
Old Aug 7, 2005 | 07:26 PM
Netko350Z's Avatar
Netko350Z
Go to the Technosquare website and try the reset on the ecu and learning procedure on the accelerator pedal release position.
www.technosquareinc.com
Old Aug 7, 2005 | 10:21 PM
theking's Avatar
theking
There is the problem. The pedal doesn't work when you have this code so their is no way to press it. I actually sent my ecu back to technosquare and Brian reflashed it. It was getting a couple weird checksum errors. We think it had to do with running the car with a very low charged optima battery.
Old Feb 17, 2006 | 10:47 PM
mistaboosta's Avatar
mistaboosta
was everything okay after reflashing your ecu?
2ndchanceZ
Oct 26, 2015 08:03 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
