Draining coolant from block Necessary?
Old Aug 15, 2005 | 06:47 PM
Go Speed Ricer's Avatar
Go Speed Ricer
Default Draining coolant from block Necessary?
Is it necessary to drain the blocks when changing fluid. If so is the fluid small enough that I can catch it in a small cup to avoid a mess of having it drop on the lower parts of the engine?
Old Aug 15, 2005 | 06:59 PM
Blue 03 Z's Avatar
Blue 03 Z
Just drain and fill the rad and you will be fine. As long as you drain and fill every year you'll be fine. If your worried about whats in the block take it somewhere and have it power flushed with a machine.
Chris350z03
Oct 8, 2023 07:19 PM
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
SharX59
Sep 27, 2015 09:23 AM
