scratched headlight
Old Nov 8, 2005 | 11:13 AM
joshp214's Avatar
joshp214
Default scratched headlight
I just bought a set of headlights, hoping they were in good shape, but one of them is not. I was wondering if you can sand the lens cover to get rid of the scratches, or would I be better off trying to buy a new lens cover (if they even sell those). Also, the other light is somewhat yellowed....what could I use to make that one look better?
Old Nov 8, 2005 | 11:25 AM
cessna's Avatar
cessna
I brought my G to my bodyman, he polished them of with a refinishing kit.... no more haze, scratches , or pitting...
The kit goes for about 60$cnd and you can do approx 10 cars.... Well worth it!!!
Goodluck, and dont let the dealer tell you to buy newones!!!
Regards,
Lou
Old Nov 8, 2005 | 11:26 AM
Soccerprep205's Avatar
Soccerprep205
If its not illegal in your state... try yellowing them out... or blacking them out (tinting) looks sick if it matches the car
Old Nov 8, 2005 | 12:03 PM
Its possible to remove a scratch in plastic, but just as time consuming and difficult as working with wood. In fact you use the same technique.
Old Nov 8, 2005 | 12:06 PM
cessna's Avatar
cessna
You would need to ensure that the lense is free from pits etc before doing so...
Old Nov 8, 2005 | 01:38 PM
ecorona6's Avatar
ecorona6
All you need is some Wet/Dry Sandpaper (3000k or 5000k I think) used for wet sanding fresh auto paint and some rubbing compound. Both can be bought at your local auto store for total of $6 at the most. Mix a drop of dish soap in bucket of water, dip sandpaper in soapy water and sand the plastic lense. The water and soap prevent the sandpaper to damage the plastic. If a deep gash is on the plastic you may not get it out, but it will work 100% on the hazing.
After a few passes with the sandpaper, dry and apply rubbing compound (has small abbreasives to further clean hazing & fine scratches). Let stand for 5 minutes and polish away! You will thank me later!
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
