Help-suggestions?
Old Dec 1, 2005 | 10:55 AM
dodbx's Avatar
dodbx
Default Help-suggestions?
My temperature gauge is fluctuating wildly. The needle will swing all the way to H (hot) then drop back down to a normal temperature reading. It does this contunually. Oil and coolant levels are normal. Any thoughts?
Old Dec 1, 2005 | 11:05 AM
fairladyinit's Avatar
fairladyinit
u may have an air bubble in ur radiator hose which is troubling ur ecu.
Old Dec 1, 2005 | 03:17 PM
DavesZ#3's Avatar
DavesZ#3
Yup, try bleeding the air out of the system.
There's a good set of instructions at the end of this DIY on changing the radiator hoses:
http://crackaddict.com/~flynn/howtos...amco.howto.htm
Old Dec 1, 2005 | 09:43 PM
dodbx's Avatar
dodbx
Thanks for the posts...I'll give it a shot.
Old Dec 3, 2005 | 08:27 PM
dodbx's Avatar
dodbx
It worked. You guys are brilliant. Thanks again.
Old Dec 4, 2005 | 12:46 AM
kbiz's Avatar
kbiz
That was so cool!! Hail the forums!!
Old Dec 4, 2005 | 02:28 PM
zlver's Avatar
zlver
you're welcome.
