Having gas door opening problems
Old Jan 17, 2003 | 05:08 AM
GaryM05's Avatar
GaryM05
I've had that problem from time to time. Sometimes I have to hit the release button pretty hard to get the gas door to open. Other times, the release on the gas door will let go, but it won't pop the door up so if I'm not careful when I go to pull it open, I'll accidentally push it back down into the lock when I'm trying to fit my finger between the door and the car frame, and then I'll have to go back and hit the button again. I'll definitely be getting this addressed when I go to the dealer for my next oil change.
Gary
Old Jan 17, 2003 | 05:45 AM
VaGentleman's Avatar
VaGentleman
In my meeting with the Technical Services Manager yesterday, he showed me why this happens.
If the cord that is attached to gas cap get in front of the "tab" that is below and to the right of the filler tube (there are 2 such tabs, both the color of the body), pressure is exerted on the release mechanism and it takes a few pushes of the button to release the door.
The fix (for now): after you screw on your gas cap, make sure the string is behind the tab and thus against the car body and not above any of the tabs.
I wish I had a digital cam so I could take pictures and show you, but I think the tabs are fairly easy to spot. There's a left tab below the filler tube which act to hold the door shut and there's a right tab about an inch or two away.
VG
Old Jan 17, 2003 | 06:04 AM
Jewelz350's Avatar
Jewelz350
Had that problem except mine would never open no matter how many times I pushed the button. Took it in and they had to replace the mechanism. Works great now (well, before it went into storage).
Old Jan 17, 2003 | 04:46 PM
Hank Nukem's Avatar
Hank Nukem
On a few occasions I've had to press the fuel lid release button multiple times to get the lid to release. I'm careful about ensuring the cap lanyard is properly routed.
Old Jan 19, 2003 | 09:34 AM
Intrepid's Avatar
Intrepid
Granted, this may be a problem. But it's not scarey. In an emergency, you could simply ask someone to open the gas door as you pull the release.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
