kinetix plenum help!!!
Old Mar 23, 2006 | 06:21 PM
steela2110's Avatar
steela2110
Default kinetix plenum help!!!
Just got done installing my kinetix v+ plenum and now the car will not start! I secured everything and made sure that all of the hoses were re-attached... The only thing that I think it could be would be the bypass for the coolant... I am confused on why the car is not starting and would appreciate any help. The car turns over and gets going for a bout a second or two, and then shuts off promptly.
Any help would be great!
Chris
Old Mar 23, 2006 | 07:02 PM
Ztalker's Avatar
Ztalker
i'd put the stock plenum back on and see what happens.
Old Mar 23, 2006 | 07:21 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You plug you TB and MAF back in?
Old Mar 23, 2006 | 07:22 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Reconnected the battery?
Old Mar 23, 2006 | 09:37 PM
bigzimmy's Avatar
bigzimmy
check to see if you re-installed the vacum lines back up to the throttle body and that the gray electrical conector is connected to the throttle body on besides that the bypass valve wouldn't cause the car to shut down it would just **** coolant just go around and re-check everything go through the install instructions backward and follow step by step.
Old Mar 23, 2006 | 10:30 PM
backagain's Avatar
backagain
if you took off the MAF make sure you have it in the right way, if not the car will do what you are describing. sounds like the maf is backwards. let us know.
Old Mar 24, 2006 | 09:08 AM
steela2110's Avatar
steela2110
The MAF is backwards??? I followed instructions and connected everything where it was supposed to go. You think it has to be something with the MAF or throttle body?
Old Mar 24, 2006 | 11:53 AM
backagain's Avatar
backagain
well, i dont know, i cant see it . but take a pic of what it looks like and post it. we will be able to tell you then, or if you cant do that just take off the MAF and reverse it. if it works then that was the problem.
Old Mar 24, 2006 | 12:05 PM
Mike Wazowski's Avatar
Mike Wazowski
step 1: remove kinetix plenum
step 2: put OEM plenum back on
step 3: return kinetix plenum and get your money back
step 4: Order Motordyne iso thermal plenum spacer
step 5: Be much happier with what you have now.
Old Mar 24, 2006 | 10:38 PM
steela2110's Avatar
steela2110
Found problem earlier today... I had a few loose bolts that were causing air to leak out! Also, I did not secure the throttle body bolts tight enough I gues...
As for the motordyne thermal spacer, I already had one, and actually wanted a change. Thanks though for the help everyone!
Old Mar 25, 2006 | 06:08 AM
backagain's Avatar
backagain
glad u got it working,
if you are going to sell the spacer let me know by PM
Old Mar 25, 2006 | 06:26 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
glad to hear you got it figured out
Old Mar 25, 2006 | 11:54 AM
MurphysZ's Avatar
MurphysZ
If your CEL came on, it will go out in a couple of days. I had it happen to me when I fail to connect a vacuum line and started the car.
Old Mar 25, 2006 | 04:21 PM
steela2110's Avatar
steela2110
Yea thanks guyzzzz... I already sold the spacer actually! sorry
allmycarsdie
May 13, 2016 04:38 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
