Car wont rev......
Hi, I took my car to the body shop a while back for some work to be done, and the car cranked and revved fine before I took it. Well, I get the car back, and it cranks fine, but wont rev for ****. It acts like it is trying to suck in air, but cant. The body shop sprayed water under the hood to clean it out, and it hasnt revved since..........any ideas what is wrong?
how high is it reving
last year i was drivin in some pretty heavy rain and i had to go through this stream/river, i had the nismo v2 at the time so my intake was submerged in water, the bybass valve worked thank god, my car ran fine for the next 100 ft or soo then it wouldnt rev past 2300rpm...so i took her home and let her sit in the garage overnight...i started her up the next morning and everything was back to normal
so they might of gotten something wet and it just needs to dry out?
well good luck
well good luck
it wont rev past idle......as soon as I touch the gas it wants to die.....I can get a sputter or 2 past idle, but thats about it. It has been 2 weeks since it has been to the body shop, so im sure it is dry. I will try resetting the ecu....is there anything under the hood that will mess up if it gets wet?
Originally Posted by baileyrx
its in limp mode
disconnect the red battery cable for about 1 min.
it should reset it
it should reset it
Well, the MAF was out of the car when it went to the body shop. I have always been able to crank the car and rev it without the MAF installed, or plugged in. I tried running it both installed and removed the other day, both having the same results. Theres no telling what small something could have happened at the shop......
Well the best is to take it to a professional shop and get it diagnosed. Clearly you have a serious problem and it's not limp mode. Also check your throttle body.
sounds.like.u.got.water.into.the.combustion.chambers.(which. is.a.VERY.serious.problem)...and.its.fighting.to.compress.at .higher.rpms
youre.lucky.the.engine.is.still.running...ive.seen.alot.of.e ngines.get.hydrolocked.(aka.blown).by.suckin.in.water
on.my.honda.i.once.sucked.in.water.(due.to.a.cold.air.intake .on.a.dropped.car...driving.through.a.puddle)
i.was.having.the.same.problem.you.was...
a.friend.suggested.that.i.remove.the.spark.plugs.and.wires.a nd.let.it.it.in.the.sun....that.way.the.chambers.dried.up... .JUST.MAKE.SURE.NOTHING.GETS.INSIDE...so.i.left.it.out.in.th e.hot.sun.for.a.couple.of.hrs....afterwards,.problem.solved. .
btw...spacebar.is.broken
Ok, update
Im just updating this so if somebody searches this topic the answer will be here. I had my MAF installed backwards. When I installed it the correct way this morning, it fired right up, and revved perfectly....boy do I feel dumb!
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
BobC-Z
Sep 18, 2015 01:57 PM
