window streaks/other things for me to whine about
Old Feb 12, 2003 | 04:23 PM
flyz33's Avatar
flyz33
Question window streaks/other things for me to whine about
well bottom line this z car kicks azz; I love it. but a few things are bothering me from making the experience perfect:
just hit 1200 btw
1- those stupid window streaks, only one on drivers side
2- the freakin seat moves/clicks when turning hard(there is a good post on a fix for this that i'm gonna try this weekend)
3- my front headlights are fogging a little bit; although recently I haven't seen it; mabey its not going to come back
4- the biggest and last problem, when switching gears is seems to grind and make unusual noises, do all z's have this? i don't think so
the main help I need is with the transmission, do you think I need a new one? I read that others are getting it replaced and are happy now. what do you think?
oh one more thing- just got the run dvd; pretty good but not worth the 9.99 plus 8$ shipping and handling; dont buy it, its nothing special
Old Feb 12, 2003 | 04:44 PM
LeMansZCa's Avatar
LeMansZCa
were u able to find a fix for the window streak? i have the same problem...
Old Feb 13, 2003 | 08:29 AM
flyz33's Avatar
flyz33
no I wiped it off and it came right back; there is something that needs to be done; but i have no clue
Old Feb 13, 2003 | 08:47 AM
del105's Avatar
del105
15 f125
Have you tried puting masking tape on your window where the streak is and rolling it up and down 500 hundred times? (dont do this if you have tint might be bad)
Old Feb 13, 2003 | 08:50 AM
zwindsor's Avatar
zwindsor
Twisty addict
Fogging head lights: this should go away with use
Window streak: remove door panel and clean rollers (dealer fix)
Don't have the other problems but they have been discussed multiple times...search
Old Feb 13, 2003 | 09:02 AM
LeMansZCa's Avatar
LeMansZCa
found some discussion on the streak... sounds like excessive oil somewhere in the door panel...
should i do the tape trick or take it to the dealer...?
maybe just do the tape trick so they don't have to mess with the car....
Old Feb 13, 2003 | 09:05 AM
zwindsor's Avatar
zwindsor
Twisty addict
I'm letting the dealer do mine when it goes in for the Bose amp replacement. The tape trick I heard is only a temp fix.
Old Feb 13, 2003 | 09:31 AM
LeMansZCa's Avatar
LeMansZCa
i am not even sure i want the dealer to mess with the amp... so far i am not getting the over boosting bass...
i just get really concerned whenever i bring the car to the nissan dealer... the service guy stare at the car like he has never seen one... u ask question about the z inside the dealer and no one knows what u r talking about... i think i will be a z expert soon!!!
Old Feb 13, 2003 | 09:55 AM
zwindsor's Avatar
zwindsor
Twisty addict
Yea, I hear ya...I don't like the idea too much either but if it needs fixing who else can you go to and get it done for free.
Old Feb 13, 2003 | 02:59 PM
LeMansZCa's Avatar
LeMansZCa
the tape trick really works!! I used medical tape and run the window up and down about 10 times....
CLEAN WINDOW!!!!
keep the grease monkey away from my Zzzzzzz....
Old Feb 13, 2003 | 03:50 PM
zwindsor's Avatar
zwindsor
Twisty addict
CLEAN WINDOW!!!!
How long does that last? I have access to med. tape too.
Old Feb 13, 2003 | 03:58 PM
flyz33's Avatar
flyz33
so the tape trick works ehh? I'll try it and post results soon.
what about my tranmission; have yall read about alot of people getting new ones?
Old Feb 13, 2003 | 05:01 PM
LeMansZCa's Avatar
LeMansZCa
don't know how long it will last.... so far so good
it's a pretty simple trick... if happens again... tape it!!!! HA! HA! HA!
Old Feb 13, 2003 | 06:09 PM
BRONXWARRIOR's Avatar
BRONXWARRIOR
hey guys dont waste your tape on the windows
the goverment says we need it for our houses to protect us from deadly gases
the tape creates an air tight barrier that nothing can penatrate.
yes im being sarcatic.
I USED A SPONGE that i taped to the window long ago it worked also but if the tape does to go for it
Old Feb 14, 2003 | 08:26 AM
flyz33's Avatar
flyz33
ha; good one;
well what about my transmission??????????????
Old Feb 14, 2003 | 09:19 AM
zwindsor's Avatar
zwindsor
Twisty addict
If you're getting a grinding sound while changing gears and you positively have the clutch fully depressed then take it in and get it evaluated.
I have no grinding what-so-ever.
Old Feb 14, 2003 | 05:52 PM
flyz33's Avatar
flyz33
well I might just have it evaulated; I just heard on this forum that many ppl where getting new trannys and that it was working out great
Old Feb 18, 2003 | 02:12 PM
golfer11's Avatar
golfer11
My dealership says that Nissan is working on yet another "fix" for the window streaks and that they'd call me when they got it (not holding my breath). I will keep calling them and if I get anywhere, I'll let you know.
Old Feb 18, 2003 | 02:49 PM
flyz33's Avatar
flyz33
alright just pm me, or post here man,
-thanks alot
Old Feb 21, 2003 | 04:37 PM
zwindsor's Avatar
zwindsor
Twisty addict
Just got back from the dealer and they are going to replace the window actuator to solve the grease problem. They had tried to remove just the grease from another car but it didn't solve the problem. The actuator was/is the problem. We'll find out next week after it's replaced.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
