Car overheating :(
Old Jun 4, 2006 | 10:20 AM
joshp214's Avatar
joshp214
Default Car overheating :(
I just got my car back together a few days ago from a wreck, and it is overheating. I can drive it normally for a few miles and it will stay at a normal temp range (in the middle), but then I floor it and get to around 6k rpms, and it starts to overheat. When I pull it in the garage and pop the hood, the upper radiator hose is hot and the lower is cold. I changed the thermostat and that doesnt fix a thing.......any ideas?
Old Jun 4, 2006 | 10:58 AM
350Zenophile's Avatar
350Zenophile
Is there any chance the water pump was damaged in the wreck? If the cooling system was drained during the repair, it's probably just an air pocket in the system. Bring it back to whomever performed the service.
Old Jun 4, 2006 | 12:45 PM
joshp214's Avatar
joshp214
Well, Im really hoping the water pump isnt the culprit, but Im not ruling it out. The engine was not touched during the wreck though. How might I check for an air pocket? I fixed everything myself, so I have no one to take it back to
It would be nice for the car to still be under warranty, but I dont know how they feel about wrecked vehicles (although it has a good title)
Old Jun 5, 2006 | 04:58 AM
350Zenophile
An air pocket would only be possible if the engine coolant was drained and refilled improperly. If the engine wasn't touched than that's unlikely and it's also unlikely that a powertrain warranty claim would be denied.
Oh, and you can also check to make sure the cooling fans are operating. When the car get's hot, pop the hood and check to make sure your fans are operating. They should also come on when the A/C is turned on.
Old Jun 5, 2006 | 06:11 AM
03Z33's Avatar
03Z33
sounds like you need to bleed the coolant.
Old Jun 5, 2006 | 07:16 AM
joshp214's Avatar
joshp214
Well, the engine wasnt touched, but a new radiator was installed. I didnt realize a particular filling procedure was necessary, so it very well could be an air pocket......Im going to try the bleeding and see what happens. Thanks guys
Old Jun 5, 2006 | 07:52 AM
350Zenophile
Make sure you bleed from the air relief plug at the high point. See attached from FSM.
File Type: pdf
Old Jun 5, 2006 | 07:53 AM
350Zenophile
Troubleshooting section from same manual:
File Type: pdf
Old Jun 5, 2006 | 09:40 AM
joshp214's Avatar
joshp214
that is just what I needed. Thanks for the help!!!
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
